Results 1 to 10 of 16
Thread: Navigation Button no longer works - 1.1.0.9
    Constant Bitrate enigmacarpc's Avatar
    Feb 2007
    NJ
    What version of StreetDeck is this bug report for?
    1.1.0.9
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your username the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the isse you are reporting.
    Please provide any relevent information regarding the issue you have encountered.
    when I press the Navigation button nothing happens when I go in to the nav settings it shows the proper comm port Prolific usb to serial comm 3 if I hit detect it says valid device can';t be found. Worked fine in last version and GPS works fine directly through mappoint.
    I just tried using the N gesture and SD takes me to the nav screen and shows me my location but the screen is weird looking and I have no controls on the screen like poi and routes.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    are you using the default skin?
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    _
    Mar 2004
    Little Elm, Texas
    I can recreate this issue on my laptop with the newest release - 1.1.0.9.
    I am using the stock skin.
    Log attached.
    Attached Files Attached Files
    Jan Bennett
    Sep 2007
    Canada
    Nav doesn't work
    same problem here. I just installed update 1.1.0.9 on top of 1.1.0.0 and the navigation button doesn't work any more.
    Not sure if this has to do with the issue but I run the mappoint test .exe and got this info:
    Found Mappoint ActiveX control at C:\Program Files\StreetDeck\Maps\MappointControl.ocx!
    StreetDeck Navigation Class ID Found in HKEY_CLASSES_ROOT registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
    StreetDeck Navigation Class ID Found in HKEY_LOCAL_MACHINE Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
    WARNING: Mappoint Class ID NOT Found in HKEY_CLASSES_ROOT registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
    WARNING: Mappoint Class ID NOT Found in HKEY_LOCAL_MACHINE Registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
    I am able to see the the map on the top left corner.
    RX-8 2006, velocity red, clear corners, rotary accents, vent fints, Racing Beat CAI, Borla Catback, Car PC, 20% tint.
    Jul 2006
    Same problem. I can get to the NAV with gestures or mapping a new button but I don't have any icons when I get there unless playing a song. I then have the bottom bar that controls the music. I've completely uninstalled streetdeck, deleted all directories and reinstalled only applying the 1.1.0.9 patch and I have the same issues.
    Newbie ScFrEaK's Avatar
    Mar 2006
    Santa Cruz, CA
    same issue, but I can get to NAV with a voice command try it, It is a stripped down NAV app but you can see where you are at.
    Beer is living proof that God loves us and wants us to be happy.
    Benjamin Franklin
    _
    Mar 2004
    Little Elm, Texas
    Thanks for all of the updates everyone. I'm sure Chuck will be reading through them.
    Jan Bennett
    Jan 2004
    Theres a problem with the skin that got put in the update. An update should be posted very shortly.
    You can extract the attached file to your default skin directory and replace skin.skn and it should now work.
    Skin.zip
    Aug 2007
    Western NY
    How about a Verbose log?
    I also have my installer logs handy if needed...
    'Burb-puter - worklog
    _
    Mar 2004
    Little Elm, Texas
    Anyone have any updates since the fix has been released?
    I've tested this with the latest update and can now get to Navigation just by pressing the navigation button.
    If there are no responses by the end of today I will assume the issue has been resolved and I will close this thread.
    Jan Bennett
  1. Infiniti/Nissan OEM Navigation help
    By normandie in forum GPS
    Last Post: 02-12-2014, 01:58 PM
  2. Google earth/ VW navigation in the works
    By ryguy in forum Software & Software Development
    Last Post: 03-14-2006, 03:20 PM
  3. Auto resume no longer works
    By Cruizer in forum RR Bug Tracker
    Last Post: 09-20-2005, 05:08 PM
  4. My MOBO no longer works
    By Eddy25 in forum General Hardware Discussion
    Last Post: 03-03-2004, 04:41 AM
  5. Exit button
    By liquid_smoke in forum Media Engine
    Last Post: 02-04-2004, 09:29 PM
