Results 1 to 3 of 3
Thread: NAV doesn't work - 1.1.1.0
    Dec 2007
    Los Angeles
    What version of StreetDeck is this bug report for?
    1.1.1.0
    Please give a basic description of the issue here.
    NAV doesn't work
    Is the system that is listed in your CarPC specs under your username the same system where you encountered this bug?
    No
    If no, please describe your system here.
    Asus R2H
    1GHz Pentium M
    1.25GB RAM
    80GB SATA HD
    GPS
    Vista Home Premium
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the isse you are reporting.
    Open SD, select "Navigation"
    Please provide any relevent information regarding the issue you have encountered.
    Downloaded SD trial, then purchased and registered. Once receiving the NAV disc, I uninstalled the previous version; then installed the version on the DVD, then upgraded to 1.1.1.0. SD loads fine, then once I click "Navigation", I get the following error message: "Navigation failed to initialize properly. Is the navigation data installed?" The only option is to then click "OK", which takes you back to the home screen.
    EDIT: ms streets & trips was previously installed/uninstalled
    Here are the error logs:
    WARNING: CNAVController::InitializeMappoint_Help - Could not find mappoint communication window! This usually means the StreetDeck Mappoint Add-In is not properly installed. Attempting to reregister.
    INFO: UV_ExecuteAndWait - Waiting for process ("regsvr32.exe" /s "C:\Program Files\StreetDeck\MappointAddin.dll")...
    INFO: UV_ExecuteAndWait - Process ("regsvr32.exe" /s "C:\Program Files\StreetDeck\MappointAddin.dll") completed.
    INFO: Message Box:
    Navigation Failed!
    Navigation failed to initailize properly. Is the navigation data installed?
    WARNING: CAVInputDeviceManager::EnumerateInputDevices - Could not find audio device id for device (@device:cm:{E0F158E1-CB04-11D0-BD4E-00A0C911CE86}\DirectSound: Speakers (SoundMAX Integrated Digital HD Audio))!
    INFO: Message Box:
    Initializing...
    Please wait while the media player initializes.
    WARNING: UV_GiveWritePermission - GetFileAttributes - The system cannot find the file specified. (ERROR=0x00000002)
    WARNING: UV_DeleteFile - DeleteFile - The system cannot find the file specified. (ERROR=0x00000002)
    WARNING: UV_DeleteFile - Failed to delete file (C:\Users\Adam\Documents\StreetDeck\wplC908.tmp)!
    INFO: Message Box:
    Initializing...
    Please wait while navigation initializes.
    INFO: Message Box:
    Navigation Failed!
    WARNING: CPlugin::Init - Invalid plugin (FMMouse.dll)! Function (SetComPort) not found while initializing dll!
    WARNING: CPlugin::Init - Invalid plugin (RadioFaker.dll)! Function (SetComPort) not found while initializing dll!
    OnPreCreate - Initialization time 0.219 / 0.219 seconds.
    WARNING: UV_GetUpdateList - The system cannot find the path specified. (ERROR=0x00000003)
    Window / Direct3D Create - Initialization time 0.016 / 0.297 seconds.
    WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = 6
    WARNING: UV_GetFileList - The system cannot find the file specified. (ERROR=0x00000002)
    WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found. (ERROR=0x0000007e)
    WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Users\Adam\Documents\StreetDeck\Plugins\Input\ InputG35SWC.dll)!
    WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Users\Adam\Documents\StreetDeck\Plugins\Input\ InputPhidgetsEncoder.dll)!
    WARNING: UV_GetFolderList - The system cannot find the path specified. (ERROR=0x00000003)
    Dec 2007
    Los Angeles
    update: just did fresh install of vista and the first app i installed was streetdeck. still no navigation... Calling support tomorrow.
    _
    Mar 2004
    Little Elm, Texas
    This does not appear to be a bug but rather a support issue. Please do not use the bug reporting forums to handle support issues. No harm, no foul, just please be aware in the future.
    Thread closed.
    Jan Bennett
  1. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 03:30 AM
  2. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 08:22 PM
  3. NAV bug? Resume navigation does not work
    By S4Per in forum StreetDeck
    Last Post: 07-07-2006, 05:28 PM
  4. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
