Results 1 to 6 of 6
Thread: XM stops playing
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    XM stops playing
    <!-- BEGIN TEMPLATE: formanswers1 -->
    What version of StreetDeck is this bug report for?
    1.0.6.3
    Please give a basic description of the issue here.
    XM stops playing
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    I can listten to XM radio.. and I have "speak major module names" enabled.. when I go back to home and then Navigation.. streetdeck says "Navigation" and then resumes playing XM radio.. but about 1 in every5 times.. it does NOT resume XM radio
    I then have to go back to XM radio and pick a different channel and it will start playing XM radio again
    <!-- END TEMPLATE: formanswers1 -->
    Jul 2006
    Baltimore
    We are simulating and testing this problem should have an answer for you by next week.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Is the option "Always send the mute command to the XM radio hardware" checked? if it is, it should be unchecked.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Aug 2004
    Pearland
    it is checked.. I will uncheck it..Thanks!!
    Aug 2004
    Pearland
    I have played around with it now for a few weeks and the solution works... can we close this bug?
    Thanks!
    _
    Mar 2004
    Little Elm, Texas
    Bug closed!
    Jan Bennett
  1. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  2. The Hibernation Blues: LineIn Mute, XM not playing
    By XxAndyxX in forum Media Engine
    Last Post: 05-22-2006, 04:34 PM
  3. XM Equipment CHEAP! XM Direct $29!!!!
    By hevnsnt in forum General Hardware Discussion
    Last Post: 04-11-2006, 10:18 PM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  5. XM RADIO_Stops after 10 minutes or so
    By Bigassbike in forum FP Bug Reports
    Last Post: 12-10-2004, 12:36 AM
