Results 1 to 6 of 6
Thread: SD does not rememeber Playlists
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    What version of StreetDeck is this bug report for?
    1.0.6.3
    Please give a basic description of the issue here.
    SD doesn't remember a playlist, whether generated via an actual playlist, or via picking music. When you shutdown SD and then restart it, it begins playing the last song played, but doesn't retain any of the the rest of the playlist. This pertains whether "Queue Music" is selected or not. The only way for SD to retain a memory of the list is to select "All Music"
    For more information, see this thread and/or this thread
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    Please provide any relevant information regarding the issue you have encountered.
    See above
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Sep 2005
    Bellevue, NE
    So, is this being corrected in the next update, or is any work being done on this, or should I "Abandon All Hope, Ye Who Enter Here"?
    Core Duo CarPC
    CarDomain page
    _
    Mar 2004
    Little Elm, Texas
    Please be patient. I'm sure the developers have seen this.
    Jan Bennett
    Jul 2006
    Baltimore
    the next update will correct this. It will be out on 4-11-07. Thank you for your input!
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Caelric, this post explains the bug report forum response policy...
    Sep 2005
    Bellevue, NE
    And as you said in your reply:
    Ah...I see. Thanks.
    Acknowledgement would be nice though...
    Thanks for pointing it out to me...
    Core Duo CarPC
    CarDomain page
  1. SD Lite Vs SD Full
    By E46M3 in forum StreetDeck
    Last Post: 02-19-2007, 02:03 PM
  2. connecting sd to headunit
    By Touran in forum StreetDeck
    Last Post: 02-01-2007, 05:13 PM
  3. How does SD handle power and shuting down?
    By Troy McClure in forum StreetDeck
    Last Post: 07-13-2006, 05:02 PM
  4. Playlists 101
    By PDiddy in forum FrodoPlayer
    Last Post: 01-19-2005, 07:19 PM
  5. Flash Memory Speeds? (CF & SD cards)
    By eCar™ in forum Off Topic
    Last Post: 03-25-2004, 01:11 AM
