Results 1 to 10 of 10
Thread: Nav buttons don't respond to keypresses...only mouse clicks
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    What version of StreetDeck is this bug report for?
    1.0.6.3
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    Since updating to 1.0.6.3, When I use the nav module, the small, square buttons on the left of the main navigation screen (the "Create new route", "Change perspective", "Virtual Earth", or "GPS info" buttons) no longer respond to keystroke activation. I can highlight them and move the highlight between them by using the keyboard or the mouse, but if I press "enter" to activate the highlighted button, nothing happens. Even stranger, if the highlight is not on the middle button when I press enter, a button above or below the middle, the highlight moves itself back to the middle button.
    However, the buttons behave properly when clicked with the mouse.
    This problem only occurs in the main nav module screen. If I create new buttons to perform the same function as the disabled buttons in the main nav module screen, the new buttons exhibit the same behavior. However, if I make a new button that performs the same function in another module (i.e. I make a new button in the main screen module to call the "Create new route" module), that new button functions correctly.
    This behavior occurs when using the default skin or my custom skin, and with the -testmode switch on and off. It occured immediately after the 1.0.5 ---> 1.0.6.3 upgrade. I've made sure the "allow keyboard/mouse focus" property is set to "true" from within the development environment, but it has had no effect. I'm wondering if this is a intentional "feature", but I can't find any reference to it anywhere or imagine why mouse selection would be allowed but keyboard disallowed.
    Help!
    Dec 2005
    Dallas, Texas
    Should we expect a response to bug reports in these forums?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    eventually they do respond, once you post here.. they start testing it.... and they wont respond until they need further input from you and/or they have fixed the bug
    which might not be until the next release
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by strohj View Post
    Ah...I see. Thanks.
    Acknowledgement would be nice though...
    Aug 2004
    Pearland
    indeed
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    This is an issue with the default skin not allowing focus for those items.. It will be fixed in 1.0.7.6.
    Quote Originally Posted by parksgm View Post
    As strojh said, we don't respond until we have more of an answer then ok. This forum is monitored daily and just by posting here, you can assume its been read.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by god_of_cpu View Post
    Great!
    Good to hear. Thanks!
    _
    Mar 2004
    Little Elm, Texas
    From your previous post elsewhere, am I correct in assuming this issue has been resolved with the 8.1 release?
    Jan Bennett
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by RedGTiVR6 View Post
    Yep. Nav onscreen buttons respond to keypresses properly now. I've even skinned some additional buttons, and those work as intended as well (which wasn't possible for me with 1.0.6.3).
    _
    Mar 2004
    Little Elm, Texas
    Issue closed then!
    Jan Bennett
  1. how do I automate mouse clicks? macro?
    By AlphaFox in forum Software & Software Development
    Last Post: 11-21-2010, 11:18 AM
  2. Any cheap four way buttons around? Mouse control
    By Mastiff in forum Input Devices
    Last Post: 10-19-2006, 05:14 PM
  3. Replies: 3
    Last Post: 07-10-2005, 06:28 PM
  4. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 09:43 PM
