Please run with -verbose and send your logs when this occurs.
What version of StreetDeck is this bug report for?
1.0.6.3
Please give a basic description of the issue here.
SD crashes unexpectedly after resume from hibernation.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Streetdeck crashes when "Create route" button is selected after resuming from hibernation. This doesn't happen after every resume, but always happens after a resume.
Sometimes, SD will allow one new route to be created, but attempting to create a second route causes the crash. As far as I can tell, the tray app is killed too, because SD doesn't offer to restart itself.
- Monthly North Texas Meet thread
- My worklog
- gDrive Install pics
- How to add your CarPC specs to your username
An amateur built the Ark. The Titanic was built by professionals.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Any updates on this parkgsm?
Jan Bennett
- My worklog
I'm gathering from a previous post elsewhere that this is no longer an issue?
Jan Bennett
Doesn't seem to be, but then again I've only had the update in the car for a couple of days now (unlike some *ahem* beta testers I know of...but I digress).
Consequently, I haven't been through that many hibernate/resume cycles, (probably a max of 10) since installing the update, and the problem previously occured most frequently when the system was resumed after sitting for a long perioid of time (overnight).
So, while I THINK this is no longer a problem, it might still be... In any case, I won't be heartbroken if you close the report.
- My worklog
Issue closed.
However, if there is still an issue, please PM me and I will reopen it for you.
Thanks!
Jan Bennett
