- Uninstall StreetDeck
- Uninstall Mappoint
- Delete Program Files\StreetDeck
- Delete My Documents\StreetDeck
- The registry is only used for the development environment. You may or may not have registry entries for StreetDeck if you do they should be under HKEY_LOCAL_MACHINE\Software\StreetDeck
- Start -> Run -> type in the following minus the quotes: 'Regedit'
- once in the registry:
- F3 "Streetdeck" once it's done:
- F3 "Mappoint"
- reboot, and reinstall
Originally Posted by god_of_cpu
Jan Bennett
