Results 1 to 2 of 2
Thread: StreetDeck Software Dependancies (Download Links)
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    StreetDeck requires a number of required and optional dependancies in order to work properly. When purchasing a complete StreetDeck system, all these dependancies are already installed with the system. You will only need to download and install these if installing StreetDeck on a non-preconfigured system.
    NOTE: The bold items in the list below are required, all others are optional, but may limit the functionality of StreetDeck if not installed
    It should also be noted that if your machine already has Map Point or Streets and Trips installed, it will cause problems when installing the full version of StreetDeck.
    Both of these programs should be completely removed from your machine before installing the full version of StreetDeck from the DVD.
    *Also, aside from Ffdshow you may need to install other codecs depending on the file types you are attempting to view.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by god_of_cpu View Post
    [*]Navigation Data (Supports Microsoft Mappoint 2004 or 2006)
    Just to clarify things, it would then be safe to install (or re-install) them (e.g. Mappoint) AFTER the full version of StreetDeck is installed, right?
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. Replies: 0
    Last Post: 01-21-2005, 10:11 AM
  2. where can i download gps software
    By SRI Allan in forum GPS
    Last Post: 05-01-2004, 02:19 PM
  3. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
