Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: StreetDeck Input Plugins (Remotes, Steering Wheel Controls, etc.)
  1. #11
    Jan 2004
    California
    Quote Originally Posted by RedGTiVR6 View Post
    According to an email from Chuck:
    Thanks for your reply!
    I did consider a possible missing dependency. To that end, I installed the software found on Phidget.com, to no avail. For what it's worth, the link geekinc provided for Phidget libraries no longer works. I can't recall for sure, but that link may have been to different software than is now available on Phidget's website.
    I also considered the phidget encoder dll was not loading correctly, which is when I attached a log file in my message above. In fact, the phidget dll is failing to load.
    WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\Administrator\My Documents\StreetDeck\Plugins\Input\Input`sEncoder. dll)!
    WARNING: UV_GetFolderList - The system cannot find the path specified.00000003
    I'm hoping that may indicate the next step to trouble-shoot this issue.
    2008 Subaru Impreza WRX-STI
    Pioneer AVIC-D3 <-- poooor comparison to StreetDeck!!!
    2003 Toyota MR2 Spyder
    Stock... for now
    SOLD - 04 WRX - In-Dash Touchscreen, MacMini, StreetDeck ver 1
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    http://www.dependencywalker.com/
    Can you run this program on the .dll and let me know what you find.
    Jan Bennett
  3. #13
    Jan 2004
    California
    Wink
    That did the trick. What a fantastic program!
    Turns out the missing link, pun intended, Phidget has recently updated their libraries. That must be why the link geekinc posted above is no longer valid.
    At any rate, when I ran Dependency Checker I found phidgetencoderplugin.dll was looking for phidget20.dll. The Phidget library I installed -- downloaded a few weeks ago from Phidgets.com -- contains phidget21.dll. Going back Phidgets.com, there is actually a link to the previous version, what they call Flash Legacy libraries, otherwise known as ver20.
    Installed up the legacy phidget library set, rebooted, and now I can see the phidget encoder plugin in StreetDeck. Taking my CarPC out to the car to verify the phidget itself is works correctly when I'm done with this post. Have no reason to think it wont.
    Thanks much for the help. Just got back from a 16 hour drive yesterday and I'll tell ya, controlling the volume on screen is a far cry from the convenience of using a phidget volume knob (encoder).
    Happy Camper.... er, CarPCer!!
    Stock... for now
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    Glad you got it figured out.
    Jan Bennett
  5. #15
    Jan 2004
    California
    Quote Originally Posted by geekinsc View Post
    Just FYI to get the Infiniti SWC or the Phidget Encoder plugin working you need to install the libraries from www.phidget.com
    As of July 07, Phidget updated their library (to version to 2.1).
    StreetDeck's phidgetencoder DLL (as of SD ver 1.1.0.0) requires phidget's 2.0 libary.
    As of today's post date, the legacy ver 2.0 phidget library can be found here:
    http://phidgets.com/downloads/Phidget20Flash.zip
    Stock... for now
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    The driver can also be found here: http://www.mp3car.com/vbulletin/down...?do=file&id=32
    In case Phidget decides to remove it from their site.
    Jan Bennett
  1. My Solution To Steering Wheel Controls
    By jcdillin in forum Input Devices
    Last Post: 12-28-2008, 01:23 PM
  2. Steering wheel controls
    By jman_97128 in forum MacCar
    Last Post: 06-25-2006, 11:36 PM
  3. Steering Wheel Controls for a Car PC
    By jbyers in forum General MP3Car Discussion
    Last Post: 08-05-2005, 04:40 PM
  4. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:24 PM
  5. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 01:40 PM
