Results 1 to 3 of 3
Thread: Executing Programs on Startup / Shutdown
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    StreetDeck offers you the ability to run any shortcut / windows executable when Streetdeck starts up, resumes from hibernate / standby, or shutsdown.
    To use this feature, simply place any shortcut or executable to be launched in the appropriate folder under Documents and Settings\<Current User>\My Documents\StreetDeck\Shortcuts\<Folder Name>
    Where <Folder Name> describes when the shortcut should be started. Any file placed in one of the folders will be launched and StreetDeck will continue to execuate. <Folder name> can be any of the following values:
    • Launch - Called when StreetDeck starts up
    • Resume - Called when StreetDeck resumes from hibernation or standby
    • Exit - Called when StreetDeck is closed
    • Sleep - Called when StreetDeck is put into standby or hibernation mode
    Additionally, in version 1.0.4.8 or later, shortcuts can be placed in the following folders and StreetDeck will wait for up to a minute per shortcut for it to execute and close. You can place .bat and .exe files directly in this directory. If you place a shortcut (.lnk), it MUST point to an executable file.
    • LaunchWait - Called when StreetDeck starts up
    • ResumeWait - Called when StreetDeck resumes from hibernation or standby
    • ExitWait - Called when StreetDeck is closed
    • SleepWait - Called when StreetDeck is put into standby or hibernation mode
    i.e. I dragged and dropped a file called "IndexMedia.exe" into
    C:\Documents and Settings\Chuck\My Documents\StreetDeck\Shortcuts\Launch and C:\Documents and Settings\Chuck\My Documents\StreetDeck\Shortcuts\Resume so it runs everytime StreetDeck is used again.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    May 2007
    App placed in LaunchWait remains minimized
    I placed an EXE file in the LaunchWait folder. SD launches and waits but the program remains minimized even though I'm commanding the app to go full screen, run and then close. When it closes, SD starts up. Will SD allow the program go full screen then close?
    Jan 2004
    StreetDeck starts all programs minimized and without activation. There is no way to change the default behavior.
  1. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  2. mouse problem again
    By lagunatl2k in forum Road Runner
    Last Post: 10-22-2005, 09:44 AM
  3. 'Intelligent' startup & shutdown controller
    By Tissy in forum Power Supplies
    Last Post: 09-16-2005, 03:19 PM
  4. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  5. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 07:07 PM
