Results 1 to 4 of 4
Thread: Uninstall a StreetDeck update
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    As of version 1.0.5.1 and later, StreetDeck now backs up all overwritten files when installing an update.
    If after updating to a new version of StreetDeck, you want to revert back to a previous version, you can do so by going to Start | Run and enter
    "C:\Program files\StreetDeck\SDUpdate.exe" -Restore
    After running the program, a list of available backup versions will be shown, select one and choose OK. The version will be restored.
    If you wish to undo the restore, just reinstall the update again.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    May 2005
    GOC...I having problems running 1.0.5.2, so naturally, this -Restore option looked like a good way to revert to something that would run.
    When I run with -Restore (I am opening a command window in c:\program files\streetdeck and then running StreetDeck), I get the message screen indicating that I have used an invalid switch.
    [[[[[ I just noticed that it is SDUpdate that has the switch so disregard the above!! ]]]
    I have double checked that I have in fact 1.0.5.2 by running online update and it indicates that I have installed the latest version.
    BTW...when SD detects an invalid command line parameter and prints the list, it would be great to have that screen print out the version of SD. It's not easy to know what version of SD one is running unless you run the developer mode or ??. When I first downloaded SD as a trial, it was not clear what version I was downloading other than to assume that it was the latest version.
    SLOJAM
    1972 'slightly enhanced' 240Z
    Epia M10000 Win XP
    Creative Soundblaster Audigy 2 ZS
    7" Touchscreen XMPCR GPS
    Jan 2004
    Just right click on the exe and goto properties and it will tell you the version.
    Aug 2006
    Munster, IN
    For those that visit this thread in the future, I would like to add that this only works within major version numbers. I think I might be having some trouble with 1.1.0.0 and it would not allow me to go back to 1.0.x.x. Something to keep in mind...
  1. Replies: 15
    Last Post: 08-21-2007, 04:46 PM
  2. Streetdeck Now Available for Purchase
    By god_of_cpu in forum StreetDeck
    Last Post: 01-02-2007, 11:58 AM
  3. Problems installing and updating streetdeck
    By segerdahl in forum StreetDeck
    Last Post: 05-26-2006, 10:48 PM
  4. Streetdeck related: Update on 2005 G35 Screen?
    By Caelric in forum StreetDeck
    Last Post: 03-08-2006, 09:13 PM
  5. StreetDeck File Extentions (.sdu and .sdz)
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 01-22-2006, 11:26 PM
