Results 11 to 20 of 22
Thread: How do I transfer or register my StreetDeck license?
  1. #11
    Feb 2006
    Melbourne, Australia
    Thanx Chuck, that clears it up for me.
    With this in mind I can then order my copy of StreetDeck
    Kind regards,
    MrBean
  2. #12
    Feb 2007
    --- Found the answer ---
    I've got a question. When I'm developing I'd like to work on my system that's in the house and not have to sit in the car. When I have something I like I'd then take the required files to the car and update the systsem. It seems to me that this would be a normal way to work.
    Given that is there a way to do this without having to buy two copies of SD?
  3. #13
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by N6BER View Post
    There is no timeout when you run the developer enviornment. You don't ever need to register any development systems. Just install streetdeck on your home machine and only run it in development mode. Things like video playback and audio is muted when in development mode because of this, but everything else is fully functional.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  4. #14
    Feb 2007
    Prattville, AL
    Smile
    Quote Originally Posted by god_of_cpu View Post
    You can change your hardware and it won't reset. You can even format and reinstall windows and it will still work. The only thing the code is tied to is your harddrive. If you pull the harddrive out that the code is tied to, you will need a new one. Other then that you can change everything else. You can even add and remove hard drives as long as you keep the one you registered on in the system. You can even add your hard drive to a different system and your code will then work for that system.
    The system was designed with upgrades in mind, even those who upgrade on a monthly basis shouldn't have much of a problem unless they throw out thier hard drive every month.
    So if I had Streetdeck installed on my laptop and then I upgraded to a larger a drive with a fresh windows install I could then install Streetdeck on the new system with new the drive and add the old drive with a usb enclosure and still be able to run Streetdeck with the existing hardware code as long as I kept the old drive hooked up? (I could have probably broken that up into several smaller sentences, but you guys get the point)
  5. #15
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    I don't think this applies if you have your drives in a raid. I have two 150GB hard drives in raid 0 and have to call in for a new registration code anytime I reinstall StreetDesk
  6. #16
    Nov 2006
    I also don't believe this applies to solid state drives. I replaced my 2.5 notebook drives in Raid 0 with a single Mtron 2.5" solid state drive. After receiving a new registration code for the solid state drive I had and issue enabling AHCI, deleted the partitions using debug. After installing StreetDeck again my Hardware and check codes are no longer the same.
  7. #17
    Jan 2004
    StreetDeck was updated so that if StreetDeck can not get get a serial number from your hard drive, it will try other means to generate a unique code based on your hardware. If this happens, it will be more sensitive to hardware changes and can change with some hardware upgrades.
  8. #18
    Feb 2008
    order id
    my order id number from mp3.com is only 5 characters but streetdeck requires 8. maybe im looking in the wring place. any help?
  9. #19
    Low Bitrate oddvarr's Avatar
    May 2007
    Norway
    Just to get this right
    If you changed your harddrive 3 times, for various reasons, you have to call Streetdeck?
    I suppose they are located in USA. I live in Norway. That would cost me close to an arm and a leg. But phone charge here is expensive.
    Any chance of doing this online because of the costs?
    If I donīt remember it. It never happened
  10. #20
    Constant Bitrate grayvader's Avatar
    Jul 2005
    Austin, TX
    What do I do if I want to transfer my license to another person (i.e. sell it)?
  1. StreetDeck License Transfer
    By god_of_cpu in forum StreetDeck
    Last Post: 04-26-2008, 09:59 AM
  2. Streetdeck Now Available for Purchase
    Last Post: 01-02-2007, 11:58 AM
  3. Do I need an extra license to develop for StreetDeck?
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 09-19-2006, 06:37 PM
  4. Transfer License
    By Zinjamaster in forum StreetDeck
    Last Post: 07-03-2006, 04:59 PM
  5. StreetDeck in Blogs
    By Fiberoptic in forum StreetDeck
    Last Post: 01-16-2006, 10:57 AM
