Results 1 to 7 of 7
Thread: button classes
    Low Bitrate TheSin's Avatar
    Sep 2006
    Thorsby, AB
    button classes
    Just wondering about editing button classes??? I can see and know how to make new ones, but how do I edit current button classes?
    Jun 2007
    Chicago
    You can open the buttons in an editing program (i.e. Photoshop), edit as you wish and then save as a .png file.
    Sep 2006
    Thorsby, AB
    ya that is what I did, just wondering if I wanted to add more, like some classes online have 3 images and others 5 for different states, but I have been able to work around it.
    I'm using the Alienware skin as my base and maybe I shouldn't have. Likely should have just started with the default skin and worked from there.
    Quote Originally Posted by ekaz View Post
    Jun 2007
    Chicago
    In my limited experience so far, I went into developer mode, created a new button class (under tools I think).
    Then I opened Photoshop and edited the new buttons. If you want to add buttons, either start with a class that has all the states you want, or create the button and save with the proper name/extension.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by TheSin View Post
    A skin image file is considered a button class if it has the word "BUTTON." in the first part of it. Following that should be the class name, followed by the state. i.e.
    The only state required for a button is NOFOCUS all other states are optional. If a state is not specified, StreetDeck will automatically use the next closest state it finds.
    To add a button manually, just copy one of the other button classes and change the class name for all the states you want and restart StreetDeck. You can also use the tool in the development environment as stated previously.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Sep 2006
    Thorsby, AB
    oh thanks this helps a lot, so basically I can make a class with only nofocus, and add the missing files and it'll just work? I hope I understood that, thus no need to edit it just add the files or remove them.
    Quote Originally Posted by god_of_cpu View Post
    Jan 2004
    Yes, you only need nofocus. If you do add more states, they should all be the same size though.
  1. Button request: Minimize
    By DaveB in forum Mobile Impact
    Last Post: 01-04-2007, 08:35 PM
  2. Changing button icons in centrafuse
    By BrentMcGhee in forum Centrafuse
    Last Post: 04-28-2006, 07:23 PM
  3. Power Button not working?
    By NoTicketsPlease in forum Newbie
    Last Post: 02-28-2006, 10:43 PM
  4. Replies: 2
    Last Post: 04-04-2005, 03:45 PM
  5. OPUS plus power button
    By The Grinch in forum Power Supplies
    Last Post: 07-25-2004, 01:55 PM
