Results 1 to 5 of 5
Thread: Skin Editor from a novice P.O.V.
    Constant Bitrate DAE51D's Avatar
    Nov 2006
    Seattle, WA
    I attempted to build my first skin -- well, actually fix many of the flaws in the default skin.
    • What is with the big empty area in the editor with the "gears" background? Is something supposed to be in there otherwise it's just a huge waste of screen real-estate.
    • Is there no 'undo' command? There seems to be the little icons for undo/redo in the tool bar but they're always ghosted out? And the Edit menu doesn't list them either. This is my number one frustration, as a novice.
    • What's with the "T" button thing in the top of the screen of my skin? Where did that come from and why?! It's annoying. It just seems to be some new subsection, which is completely useless unless you actually are creating a new module or something. Otherwise you would just be editing or adding to existing modules. I can't seem to delete it either?
    • How come when I switch in and out of Design Mode (CTRL+D) there is some white outline of the last thing that was selected?
    • I ran the 1.1.0.6 .sdu update, and SD says that's the version, yet certain things that were fixed in this version on my G4 (such as the rating stars not staying highlighted, or the album picture in the bottom not staying highlighted) are NOT fixed in the dev environment.
    • How come certain controls can't be modified? For example the album area in the lower left. I click there, there is a big white outline thing with a horizontal and vertical line and some pixel locations shown. The properties doesn't let me change any value?! "CMusicTray > Invisible" to be exact. (it's the part that obnoxiously glows that I want to set the width to encompass the whole text too, and also set PreventFocus = true.
    • Why can't I edit module screens I don't actually have? Such as the Radio or Phone ones for example? This is silly. I have a radio in my G4 *IN MY CAR* not on my notebook computer where I'm doing all the skin editing! GRRR.
    http://daevid.com/gfx/tC
    Infill G4. StreetDeck.
    Installed 09/17/07
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Welcome to the frustrating, non-intuitive world of the SD skin editor.... On the other hand, it is somewhat easier to edit SD skins, as compared to other front ends.
    Couple of answers, although you probably already have the answers, given the date of your questions:
    The 'T' button on the top screen has seemed to appear randomly to me as well, although I have never had it appear in the finalized, non-dev environment skin, once I package it for use.
    The white outline that is left behind sometimes seems to be some sort of dev environment bug; just save your progress, restart the dev eniornment, and it should be gone.
    Undo would be nice, thats for sure!!!
    As for editing module screens you don't have, I'm not sure why you can't do that; I have been able to, no problem. I don't have the phone set up yet, but I was able to edit a phone screen
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    StreetDeck Skinning Master 06TC_OWNER's Avatar
    Mar 2006
    Fort Collins
    The 'T' button is supposed to be a 'template' button. For different sections you are supposed to be able to apply the template to that entire section and it will adjust the things you moved/resized...
    Sep 2005
    Bellevue, NE
    Huh, learn something new every day!
    Core Duo CarPC
    CarDomain page
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by DAE51D View Post
    I know this is an old post, but things seem to be the same. I also have a G4 in my car and can't seem to access to edit any of the radio module on my laptop. I tried -fakedata on the outside chance it might help, no luck...
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
  4. Replies: 2
    Last Post: 11-21-2006, 04:22 PM
