Results 1 to 4 of 4
Thread: Button Text Problems
    Newbie Apache_Pilot's Avatar
    Jan 2008
    I am working on my SD skin and I am trying to adjest the text that is displayed on the button itself in SD. When I select the button panel and bring up its properties, then I edit the text of the button it looks good immediately after i complete the change. When I test out the panel and leave that module and come back to it all the text that I changed on the button panels reverts back to the defaults labels, music, video etc. Has anyone had this issue as well or is there something I am missing. It seemed like a straight forward process but apparently it's not.
    Jan 2008
    Oh here is my skin BTW
    StreetDeck Skinning Master 06TC_OWNER's Avatar
    Mar 2006
    Fort Collins
    Yep, I have seen this problem before. Delete the original buttons and add new buttons. The originals revert back...
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by Apache_Pilot View Post
    The problem is the default buttons like to shortcut functions. When a button has a shortcut function set as the function to execute when pressed, it will automatically rename the button with the name of the shortcut. This is because the user can change what the shortcut function executes. If you change the function to not be a shortcut function, you should then be able to change the text.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  1. Determining button highlight order
    By parksgm in forum StreetDeck
    Last Post: 12-19-2006, 11:38 AM
  2. label appears when button pressed? possible?
    By tja in forum Road Runner
    Last Post: 11-06-2006, 05:29 AM
  3. New Skin (partially complete)
    By a-ten in forum Freeway
    Last Post: 11-04-2006, 08:06 AM
  4. Problems with D3 Embedded in Version 1.12
    By bry21317 in forum Centrafuse
    Last Post: 01-24-2005, 05:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
