OK. I have watched the tutorial video and began to play in developer enviroment mode. I have changed the background image and simply want to make the buttons on the start page transparent or mostly see through. Can someone give me direction. I look forward to the results.![]()
EOC Memeber expanding the Horizons!
You can also use infraview its a free image editor then change the .png file to a solid color then save as transparent. Or you can just simply download a skin that already has transparent buttons (hint, hint mine does) and change your background pic to what ever you like.
Thanks I can't wait to check it out!
I know I am crawling but I know with this forums help I will be running soon.
I want to move the more button from the front module onto the setup page keeping its function the same. Than I would like to change the label to say shortcuts. What is the easiest way to move an existing button?
I tried that and it does not seem to work. I would place it in design mod, click on the button so it is highlighted and I tried ctr x, and than ctr v...nothing
I also tried using the cut and past under edit. Still nothing. What could I be missing?
You need to make sure the module or overlay you want to paste into is highlighted in the tree control. The easiest way to do this is to selet another panel in the desired module you want to paste into.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
