Works fine in the 1.1.1.6 version for me...that is a funny problem with the map covering the buttons though... is there a way to get rid of that screen alltogether?
What exactly do you mean by it doesn't "work" on 1.1.1.6. I've noticed two navigation related issues. (1) when you have the list of favorites and recent addresses the "home" button drops down and to the right so that it blocks the top address on the list (wierd?) (2) after you select where you want to go that overview map of your directions slides to the left and covers the "begin navigation" button so you are unable to actually get it to give you directions to anywhere.
The first one isn't a problem, the second one (in the words of my wife) "just won’t work" (although if you press the back button a few times I have been able to trick it to navigate). I've tried all three variation/versions of the iphone skin with the same issue.
Anyone else run into the same issue. Other than that, sweet skin still using it just because it makes the carputer that much cooler![]()
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
yoibe1, are you still using StreetDeck or doing anything further on this skin?
My opinion is my own.
yup still running SD but i need to reinstall and update the version i'm using, but i don't have time right now, but i did do some adjusting of the icar skin but need to test on the updated version of SD for bugs
i did a few more buttons in this skin. yoibe1 i hope you don't mind...
I include a voice, mute, 3d flip, weather, minimise, equilizer, bluetooth....
