I just noticed this after installing 1.0.4.4 - there is a small "video" button on the bottom left corner and when I click it, the computer speaks "test". It is hidden when you have a song playing, which is why I didn't notice it before.
Should the new Nav Views work with this skin as I copied all the required files from the default into this folder, it opens fine, but when I select the different nav views I just get a black half left side. The views work fine in the default skin.
CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
I think the skin was updated automatically... So you probably need to apply the update again if you copied over files.
Updated as in the download in the first post, or when I apply the .5 update to SD it updates the skin for me? When I did the later and tried to load the skin it bombed as it was missing files. I followed the other thread about copying over the missing files to get back into it...
Hey, G_of_C, can we get a copy of the PSD files used to create the background? I'd like to use that background as a base, but it's easier to manipulate if you have the psd files.
Dave
If you download the skin, and install it, it's inside the install folder...
The PSD files are? I'll have to check...
Shoot...totally misread that...They are PNG files...not PSD.
Thats what I thought, but I haven't had a chance to check yet. The PNG's are just like jpg's, while if you have the PSD's, with all the layers, makes it much easier to manipulate in photoshop..
Oh well.
