Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 72
Thread: Scion Night Life...
  1. #61
    Maximum Bitrate knubile's Avatar
    I've attached the dump. Here's the error from the dialog box.
    "CAppData::OnSkinLoadded - Could not import skin element (CLaunchCastFilterStationsModule)"
    Attached Files Attached Files
  2. #62
    StreetDeck Skinning Master 06TC_OWNER's Avatar
    Mar 2006
    Fort Collins
    Quote Originally Posted by knubile View Post
    It looks like launchcast is the issue - do you have it installed? And are you using 6.3 full version with launchcast?
  3. #63
    I don't have launch cast installed. Never tried it. The SD default skin works.
    I also made my own skin based on the default skin. It works too.
    I'm sure its some minor thing. The tough part is figuring it out.
    Has anybody else seen this issue?
  4. #64
    Mar 2007
    Hey 06TC_OWNER,
    First of all ure skin is amazing... its makes SD look like the classiest front end out there....
    I have posted this out there and dont seem to be getting any responses. I was wondering if it would be possible for you to change the skin a bit so that when I click the nav button iguidance loads up as an embedded application.
    If I had any programing skills I would have done it myself but I don't understand all this and mappoint is just not working for me
    below are some links that you might find handy. If you need a copy of iguidance let me know ill mail it to you.
    http://www.mp3car.com/wiki/index.php...od_%28Addin%29
    Mar 2006
    Fort Collins
    Thanks for the comment, but I guess the reason why the IGuidance system is such a bear to integrate is due to the fact that there is no sane way to control it and read values in it from a front end (at least that is how I understand it) - this forum entry: Hacking Iguidance discusses the arduous task of trying to actually hack away at the memory locations of the application in order to read values from it (God help us).
    Just out of curiousity, what detracts you from mappoint? I have seen minor nuances with it before (like the rerouting feature), but never anything that would warrant thousands of hours of programming to circumvent it?
  6. #66
    Low Bitrate djjerdog's Avatar
    Jul 2006
    Milwaukee, WI
    Does this work with version 1.0.8.1?
  7. #67
    Jul 2006
    British Columbia, Canada
    Quote Originally Posted by 06TC_OWNER View Post
    hahaha yahh Ive had some bad experiences with mappoint. for now im just dealing with it.
  8. #68
    Jul 2006
    Quote Originally Posted by djjerdog View Post
    yup works.... and is great.... definatly adds the WOW!!! factor to streetdeck
  9. #69
    Jul 2006
    Milwaukee, WI
    Runtime Error!
    I am getting a "Runtime Error!" when trying to run SD after installing the skin.
    Version 1.0.8.1
  10. #70
    Mar 2006
    Fort Collins
    This skin is back in the days of 1.0.5.8 - the interface to SD has been radically changed since then.
  1. 2005 Scion tC
    By lebshiff21 in forum Show off your project
    Last Post: 05-25-2007, 12:49 PM
  2. Night / Day Skin Code:
    By IntellaWorks in forum Coders Corner
    Last Post: 01-06-2006, 02:58 PM
  3. Replies: 31
    Last Post: 12-01-2005, 05:19 PM
  4. Childfree is the way to be (for me!)
    By R32 JUhl in forum Off Topic
    Last Post: 04-17-2005, 10:18 AM
  5. LCD Brightness at night
    By Zip-Lock in forum LCD/Display
    Last Post: 02-23-2003, 07:04 PM
