The "Header" font is something I would like to change for ALL "Headers". In developer mode you have to go through one at a time. Is there a way to do a mass change to all? (Perhaps a file that you could open in notepad and do a search/replace)?
Printable View
That would be awesome, I agree.
Even if you could define classifications of fonts (such as headers, detail, titles, etc.) to make them easier to assign to different elements of the skin...
Every generic module has a T button at the top left. If you click this button, it will take you to the template module. Any changes in the template module will be reflected through every module that has a T button. You will have to restart to see the changes though.
Also, if a change was made to the control in a specific module that is a templated control, that change will be saved with the module, not as part of the template. For example, if you change the header position to 100, 100 in the template, then go into another module that is based on the template and move the header in that module to 200, 100, then go back and change the header in the template again to 300, 100, the template in that one module that was changed will stay at 200, 100.
