If the demo is installed properly, the skin file should be registered to the StreetDeck Application. You just need to double-click on the file for the skin and SD will ask if you want to install it.
hi i am new to all this and a newbie on hereand was wondering can these skins be applied to the demo version if so how is it done as i can't seem to work it out
thanks
all its saying when i double click on it is that street deck has encountered a problem and it closes. i have tried another skin and that opens street deck and goes to the registration screen then i cancel that and it takes me to the normal screen??.
Try opening StreetDeck in window mode, then dragging the skin onto the SD window. That should accomplish the same thing.
Also, are you using anything like Minlogon? That may be part of the issue.
cheers for that , i dragged a skin into it and it worked fine. tried two more and it shut down both times so there must be a problem with the skins them self
thanks again
