Results 1 to 10 of 13
Thread: QWERT Layout....... UPDATED
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    I changed the modules around a little bit but I also corrected the QWERT keyboard layout. The search button is not hidden on this one.
    Hope this helps someone out.
    This is a zipped file... just extract it and run the sdz file.
    Download Here
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Sweet!!! Thanks a lot, sometimes lazyiness sucks, Iv been waiting for this.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Hrm, it crashes every time/way I try to install it...
    Constant Bitrate StaggRLee's Avatar
    Feb 2005
    Seattle, WA
    I can't even open the zip archive. WinZip says: "Not a valid archive".
    Aug 2006
    Atlanta, GA
    I dont know why its showing up as a ZIP file when trying to download it. I have it uploaded as a sdz and the properties of the link is sdz..... Looking into it.
    2003 E46 BMW
    Feb 2005
    Seattle, WA
    Quote Originally Posted by polo6979 View Post
    If I use WinRAR instead of WinZip, I can open the archive (whether named as a .zip or .sdz) but get an error. The error is: "Unexpected end of archive".
    If I dismiss the error dialog, I see a directory 'blaaa' and file 'version.txt'.
    I still can't extract the 'blaa' directory which contains the skin elements though; WinRAR complains that the archive is corrupt or of an unknown format.
    Thanks for the update. :thumbup:
    Aug 2006
    Atlanta, GA
    its not a compressed file at all... its just the packaged install file.
    2003 E46 BMW
    Feb 2005
    Seattle, WA
    Actually a .sdz is just a renamed .zip file. The only difference I can see is that SD adds a "version.txt" file to the archive.
    The file contains:
    1.0.6.3
    Skin
    1.0
    {00000000-0000-0000-0000-000000000000}
    I assume this is to prevent compatibility issues with skins built with earlier versions of the SDK.
    When I use the WinRAR 'Repair' tool I can extract all but one file: tabup_horiz.png
    The error is:
    ..\..\My Documents\StreetDeck\UI\Skins\S60R_4\Orig_Modded\Q WERT\rebuilt.QWERT[1].zip: CRC failed in blaaaa\tabup_horiz.png. The file is corrupt
    Aug 2006
    Atlanta, GA
    I just installed it in my car just fine.... Here is a ZIPed file
    Try extracting it and installing the sdz
    http://www.funkytechmonkey.com/stree...DECK_QWERT.zip
    2003 E46 BMW
    Feb 2005
    Seattle, WA
    OK that works. I can extract the .sdz from the .zip and then unzip the .sdz.
    The skin pkg. for distribution/install is not working well for me with 1.0.6.3.
    Thanks again!
  1. Audio CD Auto-play Playlist NOT updated
    By layanto in forum RR Bug Tracker
    Last Post: 01-03-2006, 04:40 PM
  2. Mini-ITX Layout Specifications?
    By Giuliano in forum General Hardware Discussion
    Last Post: 03-02-2004, 01:07 PM
  3. Speaker layout
    By TLK in forum General Hardware Discussion
    Last Post: 12-26-2003, 12:02 PM
  4. New layout...
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 12-17-2003, 01:59 AM
