Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Skin Development on Vista
  1. #11
    StreetDeck Skinning Master 06TC_OWNER's Avatar
    Mar 2006
    Fort Collins
    Disregard, I figured it out
  2. #12
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by JT555 View Post
    Ive been getting around vista by ctrl-alt-s for skin saves then just copying the .sdi and .skn to the car.
    Chuck, will the vista menu problems be fixed in the next release? I was waiting to find out before i go back to XP.
    Another solution would be to allow dev in GDI mode. The Virtual PC runs XP and SD fine within Vista, it just doesn't support Direct3D.
    The problems come from a library we are using that doesn't have a vista update yet. I don't know when it will be fixed, definitly not in the next update. Developer (I am Chuck)
    Get StreetDeck at
    The Official StreetDeck Forums have moved, please visit us at for official support for Streetdeck.
  3. #13
    Mar 2006
    Fort Collins
    These are the settings:
    These are the results:
    The one thing you cannot do is drag and drop images - you have to "insert" an image object, then set it to the file in the skin directory
  4. #14
    Newbie JT555's Avatar
    Apr 2005
    Atlanta, Ga
    Ahh, works perfectly under compatibility mode.
    I'm glad i can stay with Vista, i was just starting to really like it.
    thanks 06TC.
  5. #15
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    For anything that is giving you problems in Vista, do what 06TC lays out above. It will fix the issue 99% of the time. For anything that doesn't work in Vista no matter what, and you absolutely must have it, you have two choices if you don't want to get rid of Vista altogether: install XP on another partition of the HD and use a dual-boot app to have both of them, or, even easier, use Microsoft Virtual PC, and use XP as the OS on your Virtual PC.
  6. #16
    FLAC mbkowns's Avatar
    Mar 2004
    So keep running vista on your machine and use virtual pc 2007 to run xp. If your running vista at all hopefully you have the resources to run that...
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    MBK (AIM = IllMBKllI)
  7. #17
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by Nola111 View Post
    ... or, even easier, use Microsoft Virtual PC, and use XP as the OS on your Virtual PC.
    I actually tried that, but no go. SD require direct3d.MS Virtual PC uses a software virtual video card, which obviously has no hardware 3d rendering capabilities. Now you can use the -gdi command line switch to force SD to open without it, but not in the development environment.
    Quote Originally Posted by god_of_cpu View Post
    The development enviornment does not support vista yet. It will startup and you can do somethings, but the menus are non-functional.
    I've been using SD on my Vista laptop the past few days fine (finally!) Try switching of UAC from the control panel if you are having problems, if you can't get SD to even open in Vista this thread discusses what may need to be done.
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. New skin
    By Floatingpi in forum CF Skins
    Last Post: 12-22-2007, 01:31 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
  4. Replies: 2
    Last Post: 11-21-2006, 04:22 PM
  5. Spag's FD 1.0 skin development preview
    By Spaghetti in forum FreeDrive
    Last Post: 05-16-2006, 08:30 AM
