Page 13 of 17 FirstFirst ... 34567891011121314151617 LastLast
Results 121 to 130 of 165
Thread: Sygic Drive PC
  1. #121
    Constant Bitrate Jon-G's Avatar
    Jun 2005
    Chesterfield, UK
    has there been any hint as to a release date for this yet? Im at the stage where the bench work for my system is almost complete, and its ready to install. Although this looks amazing, I dont want to install this if I cant run it for any length of time!
  2. #122
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Jon-G View Post
    hmm, I've been using it for 2-3 months in my car... get a membership at www.digital-car.co.uk and search for Sygic there!
    Swedish site for CarPC's
    http://www.bilpc.info
  3. #123
    May 2008
    You can use this software:
    http://www.pocket.co.il/community/sh...3&postcount=36
    It was tested and it is working.
    (Also tested on maps PAK files)
    You can extract pak files with pakExtract and repack files using pakU
  4. #124
    May 2008
    Quote Originally Posted by kelmk View Post
    Does anyone know how to extract the voice .pak files? I tried winzip and a couple other .pak extractors and none of them work.
    Quote Originally Posted by tatoosh11 View Post
    Hi together.
    i read every of the 46 pages and searched for the audio pak files.
    the extractor from page 1 works fine ... is there still no repacking solution??
    i want to add a short held at each file for my car hands-free equipment.
    thx
    Well actually there is something called PAK Handler which have 2 programs inside: 1 for extracting and one for packing.
    I know that it is a late response but it is better late than never.
    Use pakExtract for extracting files from a PAK file into a directory.
    Use pakU for repacking files back from a directory to a PAK file.
    It also works for Maps PAK files.
    When the program extracts the files it creates a small text file called FilesList.txt inside the folder where you have extracted the files.
    When you repack then it checks for a mismatch (a file was added or deleted) and informs you if a mismatch was found (just to let you know).
    Also, when you extract the files, it renames the Wav files to Ogg (other extensions are not being altered) since the wav files are actualy Ogg files (just look at the header of the file using an Hex Editor).
    When repacking, the software renames back from Ogg to wav (so you don't need to worry about it).
    Works like a charm.
  5. #125
    Nov 2005
    Quote Originally Posted by NoNothing View Post
    I started by modifying the example app to desktop from mobile and from there I was able to code. All I have done so far is load DRIVE, enter my address and go to it on DRIVE. I havent done too much yet. But it definitly is working for me.
    I used the SDK from the link you provided (I dont recall version off hand). I am using Visual Studio 2008 and converted the project to a VS9 format.
    do you mind to hand source code / project over to me. i want to include a native poi (speedcam) reminder function if i am approaching one and showing it in road runner as label (in case i am not on navi screen)
  6. #126
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Hi,
    Anybody know how to disable the auto volume thing, that is function that increases the volume when going faster and vice versa. I feel like this is a annoying function. Maybe Drivemon can fix this?
    br,
    Tom
  7. #127
    May 2008
    New version for the PAK Handler:
    Link:
    http://rapidshare.com/files/14930732...ndler.rar.html
    Those are the fixes from the old version to the new one:
    Version Changes:
    1) Applications captions were "Virtual Mouse"
    2) On pakU the labels are switched ("PAK file" instead of "Directory" and "Directory" instead of "PAK file")
    3) Sometimes browing a folder in the pakU and pressing cancel causes the files list to show the files on C:\
    4) Great speed improvement on opening big files (Like Maps pak files):
    On a P3 600Mhz, opening the canada pak file using the old version would take 65 seconds and with the new version it would take only 13 seconds
    5) Fixed: Could not extract pak files that contain 0 bytes files inside.
    6) Fixed: Could not repack a directory which contained 0 bytes files.
    7) Fixed: Runtime error when trying to repack an empty directory.
    This program can also pack or unpack maps pak files.
  8. #128
    Apr 2006
    Hi where can I get pak handler?
    Link does not work anymore.
    Edit:
    Never mind direct link from here does not work, so...
    Just put "PAK_Handler.rar" in google en you find it on list to rapidshare.
  9. #129
    May 2008
    Quote Originally Posted by Captain Nguyen View Post
    Edit:
    Make sure you got the latest version....
    Link:
    Version Changes:
    Beside from packing and unpacking PAK sound files of sygic, this program can also pack or unpack maps pak files. (Since those files are in the same format: PAK)
  10. #130
    Nov 2008
    Someone knows if it's able to use voices from a TomTom GPS in Sygic? Would be really appreciated.
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  3. Replies: 6
    Last Post: 04-07-2005, 10:15 AM
  4. FS: PC cards: video, audio, network; CD drive
    By BriCubz in forum Classified Archive
    Last Post: 08-28-2004, 01:12 PM
  5. Connecting a PC hard drive to laptop?
    By Yuriy in forum General Hardware Discussion
    Last Post: 07-01-2004, 10:49 PM
