no, in RR it works right, set up the app name in CaVe
has anyone figured out a way to get it to run borderless (ie. no window borders)
I want to embed it into the Cave Live frontend but I can't get rid of the borders around the window.. the only way i've found it to set it full screen but then my frontend buttons sit over some of the Sygic window![]()
Englishlessness :(
I cannot believe this software Sygic Drive v7 has not gotten more attention in this forums. I downloaded a demo, and it is absolutely stunning! Perfect for CarPC!!! It is better than Tom Tom itself, unbelievable!
I don't think there are US maps available yet though, but I played with the UK maps, and it is just amazing!!
http://sygic.com/
http://www.sygic.com/manuals/manual_en.html
http://www.solocarputer.com/phpbb2/v...er=asc&start=0
Demo here: http://www.allview.ro/gps/site/fisie...L/DRIVE_XP.zip
(Seems fully working)
UK Map: ftp://ftp.maporama.com/DRIVEME_2007/...ed_kingdom.zip
Youtube video: http://youtube.com/watch?v=LjrnfVDmO78
You can change language to English if you go to options menu etc...
We need US MAPS!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
The Sygic Drive USA/Canada maps are just around the corner![]()
Anyone got any ideas how i can set the window size as default.
Im trying to use the Cfig plugin in centrafuse and use this sat nav, but its not embedding properly...as its too small. any ideas?
2002 Honda CR-V
I tried this today. It's fantastic. I've also integrated speed cameras with voice alerting into it. They seem to work ok but I'll test them on the road tomorrow.
I tried this software and it looks promising but I have a problem connecting to my GPS port.
I tried to autodetect it but it fails with "GPS port not found" when I tried to define a port it fails with "opening failed, checkout your settings".
Anyone have had any luck with opening a connection to the GPS?
Failure is not an option...
_________________________________________
The open source C# Front End -> OpenMobile
create a folder in the install dir like so
drivers\default
copy Device.dll and Driver.dll in there. Then try it.
Hmm... This worked on my desktop, I could now select the comport from a list but for some kind of reason it doesnt work on the laptop that I'm using in my car. They are both running WinXP.
