Page 4 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 165
Thread: Sygic Drive PC
  1. #31
    Constant Bitrate Beezer's Avatar
    Oct 2006
    Quote Originally Posted by Borte View Post
    Hmm... This worked on my desktop, I could now select the comport from a list but for some kind of reason it doesnt work on the laptop that I'm using in my car. They are both running WinXP.
    Remove the 2 driver lines from settings.ini so it looks like so....
    [Drivers]
    [WorldClock_Zones]
    And remove settings.dat
  2. #32
    Variable Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by Beezer View Post
    [Drivers]
    [WorldClock_Zones]
    This did the trick. Thank you for all your help Beezer!
    Failure is not an option...
    _________________________________________
    The open source C# Front End -> OpenMobile
  3. #33
    Dec 2006
    I managed to embed the software into the Cfig plugin in centrafuse, and I can make it resize how it needs to....but the position doesnt change. doesnt matter what I set the position to.....it still cuts the top off the embedded sygic application.
    Anyone got any ideas?
  4. #34
    Dec 2006
    sorry, solved that now, only thing i need to know is how i can input the camera locations available for the uk, into the software from the spreadsheet on the freedrive website???
    If anyone can tell me that - i'll be flying!!!
  5. #35
    Aug 2006
    Quote Originally Posted by astrapc View Post
    Not sure how you can do it from the spreadsheet on freedrive, but if you get the tomtom speedcam files and use a program called OV2UPI Translator 2.1 (google it) then you can covert them to the correct format for this program.
  6. #36
    Dec 2006
    and what function, or what setting points the nav program to the database once converted?
  7. #37
    Aug 2006
    You just have to drop the converted POI's into your map folder (the UPI files) and then from inside the Sygic drive menu you can turn them on (Menu, Manage POI)
  8. #38
    Raw Wave justintime's Avatar
    Apr 2005
    you guys found a USA map for Sygic?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  9. #39
    Oct 2006
    Quote Originally Posted by swift_gti View Post
    Thats how I done it, using the Tom Tom files from PocketGPS. It probably wouldn't be right for me to post the files here but I will post a howto instead.
    1) Get PocketGPS speed cameras for Tom Tom. I got the November 2007 release. The files should be .ov2 files, one for each camera type, e.g
    pocketgps_uk_gatso_20.ov2
    pocketgps_uk_gatso_30.ov2
    pocketgps_uk_gatso_40.ov2
    .... etc etc
    Make sure that you have the equivalent logos in bmp format for the files. e.g.
    .... etc etc
    4) run ov2upi, but run it for each ov2 file individually. I found that it didn't work properly when you told it to convert an entire directory at once.
    5) You should have lots of upi files now.
    pocketgps_uk_gatso_20.upi
    pocketgps_uk_gatso_30.upi
    pocketgps_uk_gatso_40.upi
    .... etc etc
    Rename these to whatever you want to appear inside Sygic Drive. e.g. I named mine
    Fixed Speed Camera @ 20.upi
    Fixed Speed Camera @ 30.upi
    Fixed Speed Camera @ 40.upi
    .... etc etc
    6) Copy these upi files into your map directory e.g. GBR. Don't copy default.upi
    7) Copy all bmp files into the Icons directory in Sygic Drive. Don't rename them. IIRC a few don't display properly so you have to load them into Irfanview or something & increase their colours to 8bit.
    8) If you load up Sygic Drive now, you should see new categories in your POI management. You should see them named however you named the file & you should see an icon to the left of the name. If you enable them & look at the map, you should see the icon on the map.
    9) If you want alerting as you approach a camera, you have to do the following...
    10) copy wav files into the Sounds directory for your alerts. Get these from wherever you fancy. Personally, I used the ones from GatsohunterRR which in turn were borrowed from FreeDrive.
    11) Edit SKIN/application.skin. USE NOTEPAD NOT WORDPAD. search for "managePOI.alarm". You should see 3 lists. items, sounds & icons. You need to add new items referencing the sounds that you added using a default icon. You can't add your own icons. Make up the name for the item for now - anything you want. e.g. here's mine
    <listBox id="listBox.managePOI.selectSound" bitmapSound="_b.checkOff"
    items="
    managePOI.alarm
    managePOI.alarm
    managePOI.alarm
    managePOI.alarm
    managePOI.ring
    managePOI.ring
    managePOI.ring
    managePOI.beep
    managePOI.beep
    managePOI.beep
    managePOI.cam30
    managePOI.cam40
    managePOI.cam50
    managePOI.cam60
    managePOI.cam70
    managePOI.camera
    managePOI.mobile
    managePOI.redlight
    managePOI.speed"
    sounds="
    Sounds\Beep.wav
    Sounds\Beep2.wav
    Sounds\Beep3.wav
    Sounds\Beep4.wav
    Sounds\Bell.wav
    Sounds\Phone.wav
    Sounds\Ring.wav
    Sounds\Whistle.wav
    Sounds\Beep2.wav
    Sounds\Alarm2.wav
    Sounds\cam30.wav
    Sounds\cam40.wav
    Sounds\cam50.wav
    Sounds\cam60.wav
    Sounds\cam70.wav
    Sounds\Camera.wav
    Sounds\mobile.wav
    Sounds\redlight.wav
    Sounds\speed.wav"
    icons="
    _i.alertBeep
    _i.alertBeep
    _i.alertBeep
    _i.alertBeep
    _i.alertRing
    _i.alertRing
    _i.alertRing
    _i.alertAlarm
    _i.alertAlarm
    _i.alertBeep
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    _i.alertAlarm
    Save it
    12) Edit SKIN/English.lang (or whatever your lang is). USE NOTEPAD NOT WORDPAD
    Search for <lang id="managePOI.beep" text="Beep"/> Copy that line & add your new items as you want them to appear in the menu using the names you chose in the previous step.
    e.g. here's mine
    <lang id="managePOI.cam30" text="Speed Camera @ 30"/>
    <lang id="managePOI.cam40" text="Speed Camera @ 40"/>
    <lang id="managePOI.cam50" text="Speed Camera @ 50"/>
    <lang id="managePOI.cam60" text="Speed Camera @ 60"/>
    <lang id="managePOI.cam70" text="Speed Camera @ 70"/>
    <lang id="managePOI.camera" text="Camera"/>
    <lang id="managePOI.mobile" text="Mobile Speed Camera"/>
    <lang id="managePOI.redlight" text="Redlight Camera"/>
    <lang id="managePOI.speed" text="Speed Camera"/>
    13) Load Sygic Drive, go to the Manage POI section & add an alert for your speed cameras. The alert sounds menu should now show the new items you entered.
  10. #40
    Dec 2006
    forgive my stupidity.....poi converter doesnt offer a .upi file extension to save siles as?
    And the ov2upi translator software gives error initialising when i try to open it?
    Anyone able to assist me?
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  3. Replies: 6
    Last Post: 04-07-2005, 10:15 AM
  4. FS: PC cards: video, audio, network; CD drive
    By BriCubz in forum Classified Archive
    Last Post: 08-28-2004, 01:12 PM
  5. Connecting a PC hard drive to laptop?
    By Yuriy in forum General Hardware Discussion
    Last Post: 07-01-2004, 10:49 PM
