Page 9 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 81 to 90 of 165
Thread: Sygic Drive PC
  1. #81
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by GTO View Post
    I don't get IE now, but I don't get Drive either.
    Thanks for the help.
    http://www.mp3car.com/vbulletin/1164101-post70.html
  2. #82
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Thanks but as I know nothing about skinning, skins or how they work that really means nothing to me.
  3. #83
    Oct 2003
    Copenhagen, Denmark
    I would encourage you to read the general embedding faq in the RR forum instead, theres alot of great info there, that you can use not only for this GPS part, but also for other applications you wan't to embed.
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
  4. #84
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Quote Originally Posted by _dopehead_ View Post
    Thanks, I'll do some more reading up.
    My main problem is that I can get it to embed in RR but not resize. If I put anything after "C:\Program Files\Drive_XP\Drive.exe" it won't start up in RR.
  5. #85
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    I can help you there i had a similar problem.
    If you are loading Sygic off of a button, the COMMAND properties of this button should read:
    "LOAD;sygic.skin;!Sygic DRIVE;C:\Program Files\DRIVE_XP\drive.exe |-no-safety -r800x520;!Sygic DRIVE||ACTIVATE;Sygic DRIVE"
    Your best bet is to copy and paste exactly as i have done above (obvioulsy changing any of the necessary file paths you require).
    The r800x520 is the dimesnions of the SYGIC application, so again you can change these to your liking.
    I made a simple sygic.skin which looks like this:
    MEDIACAR Skin
    MEDIACAR IGUIDANCE. Skin
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L04,309,31,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",
    L01,9,31,287,35,255,102,0,18,"Digital Readout Thick Upright:B","TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    /, A, x, y, w, h, color R;RGB, G, B
    A01,0,77,800,520,255,255,255
    END
    Hope this helps
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  6. #86
    Oct 2003
    Madrid
    Try it like this - C:\Program Files\Drive_XP\Drive.exe " " r800x600 p50x10 s
    If that doesn't work then there is somewhere in RR GPS config that you can add options, I don't use RR but I've seen someone mention it before. Search the RR sub forum, there is a FAQ!
  7. #87
    Nov 2005
    does anybody know if i can use keyboard shortcuts (page up or down) to change the zoom level in sygic.
    the buttons on the sygic screen are too small for touchscreen usage and the zoom level does not change very visible, i.e. clicking three or four times on - button really brings you a different view of the map.
    i then would like a road runner screen button with, let's say threy keystrokes, to zoom in / out. i know how to assign buttons in the EXECTBL.ini.
    thank you
  8. #88
    Nov 2005
    another question sygic related:
    i am often listening very loud (bass) music during driving. if then the voice jumps in, it almost blows my ears (and loudspeakers). you can easily listen techno and rap at high volumes but voices only tend to distort.
    is there a way to have voice commands to be outputted at 50% of the current music volume (interrupting/pausing the music) and then resume full power music playback?
  9. #89
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Quote Originally Posted by Laidback View Post
    Thanks Laidback that worked.
    And thanks to Tissy for your time.
  10. #90
    Nov 2005
    question/remark number three and four:-)
    1. i notice a small lag from my current real position and the arrow of the car on the map. it is about 5-10 meters and is especially ugly when you are about to turn. let's say i do a left turn, sygic drive then seems to continue straigth for 1 or 2 secs, means not following the own proposed route and then jumps back into my left turn. most of the time the map is also oriented wrongly then, i.e. 90 degrees. am i clear? who noticed the same behaviour? it is very confusing, especially if you don't know the area, do a turn as proposed, want to double-check on the map and then sygic shows you something else. i already lost orientation with this many times. iguidance is never doing this. well it also does less smooth moving of cards. but what does it give to me if i have smooth animation but unclear orientation. i expect sygic to "interpolate" in first hand that i follow its instructions and scrolls the map the way the route goes and not just going straitgh.
    2. sygic drive does calculate its routes in general well but i realized that it tries to guide you often through clearly marked pedestrian areas? is this due to the map material (doubt since it is teleatlas which is used for many other navigation systems) or does their routing procedure not taking care of it?
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  3. Replies: 6
    Last Post: 04-07-2005, 10:15 AM
  4. FS: PC cards: video, audio, network; CD drive
    By BriCubz in forum Classified Archive
    Last Post: 08-28-2004, 01:12 PM
  5. Connecting a PC hard drive to laptop?
    By Yuriy in forum General Hardware Discussion
    Last Post: 07-01-2004, 10:49 PM
