bump
Okay i have a problem i went from mm to Sygic, got that all working and mounted in RR but is now there are no buttons anymore to controll the music as in mm (using Apline skin and kinda love that one)
Also if you leave gps and come back it doesnt reload .. when using mm it was ok to leave the gps and come back later and it would still be working
Volvo 760 Turbo Intecooler
M900 + 512MB, 120GB HD, VroomPC casing, Wired GPS unit, Flipscreen 7"
bump
sounds like your window is just covering up RR controls? It may not be embedded correctly. Do you have a screenshot?
MM uses DESTINATOR_GPS.SKIN while external GPS software (i.e. Sygic) would use EXTERNAL_GPS.SKIN -- this may be the difference you're seeing on the RR screen. You should make a backup of EXTERNAL_GPS.SKIN and rename DESTINATOR_GPS.SKIN to EXTERNAL_GPS.SKIN then try to see if the result is what you want.
Ride Runner RR's Myspace
