do you have any info on how to use this with RR?
Did someone got the newest Fleet SDK?
They updated their SDK on 22.12.09
http://www.sygic.com/index.php/en/do...mentation.html
Im writing an LCD Plugin which should show the next turn. This info is now included in the newest SDK.
So if anyone has this SDK please tell us.
Code:public static int GetNextInstruction( out SError Error, out SRouteInstruction Instruction, int MaxTime ); Public Instance Fields lDistanceToNextTurn Distance to next turn [m] lNextTurnX Next turn longitude lNextTurnY Next turn latitude nInstruction Next turn instruction. See Instruction enum. nRoundaboutExitIndex Roundabout exit index Members Member Name Description DirectionKeepRight DirectionKeepLeft DirectionEasyRight DirectionEasyLeft DirectionRight DirectionLeft DirectionSharpRight DirectionSharpLeft DirectionStraight DirectionUTurnRight DirectionUTurnLeft DirectionEnd DirectionStart DirectionOutOfRoute DirectionRoundaboutSE Valid only in the countries where you drive on the right side DirectionRoundaboutE Valid only in the countries where you drive on the right side DirectionRoundaboutNE Valid only in the countries where you drive on the right side DirectionRoundaboutN Valid only in the countries where you drive on the right side DirectionRoundaboutNW Valid only in the countries where you drive on the right side DirectionRoundaboutW Valid only in the countries where you drive on the right side DirectionRoundaboutSW Valid only in the countries where you drive on the right side DirectionRoundaboutS Valid only in the countries where you drive on the right side DirectionRoundaboutSW_LS Valid only in the countries where you drive on the left side DirectionRoundaboutW_LS Valid only in the countries where you drive on the left side DirectionRoundaboutNW_LS Valid only in the countries where you drive on the left side DirectionRoundaboutN_LS Valid only in the countries where you drive on the left side DirectionRoundaboutNE_LS Valid only in the countries where you drive on the left side DirectionRoundaboutE_LS Valid only in the countries where you drive on the left side DirectionRoundaboutSE_LS Valid only in the countries where you drive on the left side DirectionRoundaboutS_LS Valid only in the countries where you drive on the left side DirectionFerry DirectionStateBoundary DirectionExitRight DirectionExitLeft DirectionMotorway
Blessed are the "cracked" for it is they who let in the light.
