Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Video FAQ: How to put a PC in your car
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    A very quick 5 minute video how-to for putting a PC in your car, featuring my Mac Mini install in the iBug. The basics are the same for a PC installation.
    [MEDIA]http://www.youtube.com/watch?v=RAubCPJhS_U[/MEDIA]
    If media embedding above does not work, go to this link: Car PC 101 for the newbie
    Want to:
    Feb 2006
    Nicely done!!!
    Jun 2007
    Excellent! Way to go on this!
    Elsewhere
    I gotta bust some chops here...
    Installing a carPC in your car.
    Uhhhh... Where else would you install a carPC?
    At least you admit you're too cheap to buy an amplifier...
    Overall, it's very well done and very informative. Kudos, BB!
    How about the Wiki?
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Good job
    I must bust your chops on this one though. Seriously....
    Where is your grommet protecting the power wire that runs through the hole you drilled in the metal?
    If Red saw that she would be all over you on that one too. That could be potential fire hazard if it slowly makes connection and starts sparking even if you are protected by a fuse.
    _
    Mar 2004
    Little Elm, Texas
    durwood....you beat me to it.
    I posted the vid in the faq in the nav bar faq, but I didn't watch the whole thing.
    bug - you know....you should....
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I know, I know. I ought to know better, but that's what the fuse is for, after all!
    Seriously, I didn't have a grommet and I basically forgot after I installed it. There's probably a lot of other stuff that would horrify you about my install as well. Let's just say that it looks better on video than in real life.
    Want to:
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by DarquePervert View Post
    For convenience:
    I got it embedded in the orginal post, thanks. I was getting a database error earlier.
    Umm...and I fixed the redundant redundancies. At least in the post. I'm not going to re-edit the video just to fix that. I was winging it the whole way anyhow.
    Want to:
    _
    Mar 2004
    Little Elm, Texas
    bah!
    just don't rely on the fuse in the future...
    Jan Bennett
    Oct 2004
    NY
    quick tip, if you don't have a gromet, silicone can be used for an acceptable finish, coat the whole hole & wire, stick it in a bit more & a bit more silicone.
    the difference is that a grommet will garentee the wire has a rubber barrier to the sharp edge where with silicone it can still have the wire touching the edge, but if it doesn't move at all (it won't when fully cured) it' a whole lot better than just drilling a wire & sticking it in a dry sharp hole
  1. Car PC & Bose/Philips CCR800 Aux input
    By Gamer64 in forum Car Audio
    Last Post: 01-25-2007, 04:13 PM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 01:49 AM
