Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: FAQ: RELAYS; how they work and how to wire it up...
  1. #11
    Oct 2008
    Instead of hooking up to the ACC or IGN line, could I hook up to the 12v direct battery line? That way I can keep the PC on, but still use a kill switch as OPPOSED to the ACC/IGN
  2. #12
    Aug 2009
    Birmingham - UK
    Quote Originally Posted by az350z View Post
    that would defeat nthe purpose of the relay. the relay turns the 12v [highload] supply on and off with a [low load]
    so say 5v can then turn on the 12v source.
    i think you want an "On/Off" switch to replace the ignition
    IE:
    -------------[Switch Pos]-------|
    --------[Switch NEG]---------[RELAY] ----------------- POWER OUT [direct from battery to units]
    ---------[BATTERY POS]--------|
    [edit]
    also.... you can use a shutdown controller that basically does this... but: if the computer is powered on, leave the power supply on, until the computer shuts down, then close the power supply off... not sure how thats done, im using a laptop with a pretty decent battery, so i can run my battery perfectly fine :P for turning off the laptop on power loss after say "10 mins" [leaving time to get petrol, or run n get some milk from shop etc]
  3. #13
    Newbie MRJERRY300ZX's Avatar
    Oct 2009
    Houston, Texas
    I need some help!
    Hi I'm new to site, I don't have any experiance with relays so I searched and searched and finally ran across this site. Now I'm doing a custom engine swap and it has some realys
    (2 of them) that need to be hooked up, to actually start it. They give the diagram on how to hook it up but no numbers( 30,85,86,87,87a) can somebody please help me it would be greatly appreciated!! I only need info on the boxed portion. sorry it wouldn't let me put the box any other color than gray!!
  4. #14
    May 2012
    relay on scooter
    hi i am wireing relay on my son scooter the thing is is that the headlights run straight from the altenator so when i wire it all up the lights dont work i am doing this cus the areox lights are **** and wanted to put h3 or h4 on it please help out tell me which relay to use if any can thanks ian
  5. #15
    Aug 2012
    hi! this is my first post and i am quite a noob with electronics so i hope you would bear with me. is my wiring possible -
    IGN to 30, 87a (NC) to accessory i.e. DRL
    Tap from Park Light to 85, 86 to ground
    87 (NO) not used.
    if so, will i also need a signal diode from 85 to 86 and how to solder that i.e, between wires or the relay's plugs?
    please advise. thanks!
  6. #16
    Feb 2015
    thanks for posting it really helpful dude.I want to learn more and also want to share my knowledge with people like you.I hope so that this forum will help me to increase my knowledge.
    http://www.trendzmania.com/c/women/c...r-and-wide-leg
  7. #17
    Jun 2015
    Nice guide! I've known how relays work but never knew what each pin is on car relays
  1. ATTN: FV24 owners: How to wire a microphone
    By Alives in forum General Hardware Discussion
    Last Post: 03-25-2006, 04:48 PM
  2. How do album covers work for MP3
    By rgardjr in forum MediaCar
    Last Post: 09-07-2004, 12:23 PM
  3. How does activation work in Copilot?
    By [H]Bugster in forum GPS
    Last Post: 11-16-2003, 12:39 AM
  4. How to wire a laptop lcd to vga cord?
    By acebrooks44 in forum Newbie
    Last Post: 10-09-2003, 09:13 PM
  5. Slimline IDE Adapter - How does it work?
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2003, 11:46 PM
