Results 21 to 30 of 34
Thread: Frequently Asked Questions
  1. #21
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Enforcer
    Remind me NOT to accept a lift from you.
    No worries... the interesting thing about the wreck is none of them were my fault.
    TruckinMP3
    Read the FAQ!
  2. #22
    Oct 2004
    NY
    Quote Originally Posted by TruckinMP3
    HMMMMMM, I own a body shop & I talk to many who are involved in accidents & I can tell you that at least 90% of the accidents are "not my fault..."..I guess all of the people causing the accidents are going to a different shop?
  3. #23
    Jun 2002
    Colorado
    Quote Originally Posted by turbocad6
    Buy a vowel, I was rearended 3 times.... one of them the other driver was drunk, one on a cell phone the third was digging in her purse.
    The big one a driver turned left across my line of travel (was ticketed for failure to yeild) Then he stopped across my lane.... traffic in the lane on one side of me and a median on the other. No where to go and the distance was 15 feet.
    TruckinMP3
    Read the FAQ!
  4. #24
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Hey! Keep on topic please.
  5. #25
    Oct 2004
    How about making a wiki out of all this info? Make different categories, and allow all the real info to build up there; it should take traffic off the forum and reduce chatter for people looking for info.
    Alex
  6. #26
    Newbie shinny's Avatar
    Feb 2005
    Bristol, UK
    What are the standard dimensions for a head unit?
    Edit: I found these dimension for the external dimeters of a head unit - 7" x 1-15/16" x 6-11/16"
    Are they right? And has anyone ever sqeezed a mini-itx inside a head unit?
  7. #27
    Mar 2005
    wiki
    I second the idea of starting a wiki. Using threads works well but a wiki is much more easier to navigate and update.
  8. #28
    Mar 2005
    scuse the ignorance.. but what the heck is a wiki..?
    would an inverter running a standard home pc run ok in a car? what sorta wattage inverter would u need to do this? i wouldnt mind making one with a lil case n stuff, but just for mucking around and seeing what i can do at this point..
  9. #29
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    Quote Originally Posted by stinger
    I have had problems with inverters (small ones) and my laptop. If the battery is not fully charged it drains more juice from the inverter to get back to full charge. This caused my inverter to over heat. I hung it in front of the AC to cool it off and it worked fine. I would suggest getting a better inverter if you choose that route. Mount it someplace it will get air flowing over it.
    With an inverter and nothing else, you will have to boot each time you start your car, or drain your battery. I believe.
    If I could point you in the direction of the information about Power supply power consumption and inverter requirements I would, but I'm not sure where that information is, I'm sorry.
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  10. #30
    Newbie Wyattx17's Avatar
    Apr 2005
    California
    Quote Originally Posted by kmcniece
    Wouldn't a battery backup Help this situation? I am thinking of running UPS off the inverter (400 watt+). Any one have any opposing opinions?
