Page 10 of 15 FirstFirst 123456789101112131415 LastLast
Results 91 to 100 of 148
Thread: HOW TO: Get sound from PC to Car Stereo / Amp
  1. #91
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by chrislloyd
    i have been looking through this thread and am confused on something. everyone is talking about 5.1 and such.... but noone mentions anything about time alignment. the whole idea with 5.1 is that you get sound from all these differnet speakers to your ears at certain times. well in a car.. you sit to the left of a center speaker. you practically sit ontop of the left speaker.
    for those of you going straight from a 5.1 card to an amp... how are you dealing with time alignment? does the hardware app/firmware support this? is there external software that does it??
    i just ordered my carpc... and am still wrestling with the idea of keeping my head unit (time alingment built in) or going straight from the carpc.
    thanks
    The Sound Blaster Audigy ZS Pro i have at home has THX time alignment. It runs through a set of tests and angles.
    The Sound Blaster Audigy NX USB I have in my car doesn't have this allignment. You will need a better soundcard I think for that.
    I have my NX going to a 4 Ch amp and a 2 Ch amp for my Sub. I set it on 5.1 and lowered the center channel slider in the Creative speaker setup.
    You can lower the front left slider for the front right channel and boost up the rears if you want, but then your passengers won't get the effect then. Too bad we don't drive in the center of the car. That would be best for racing.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #92
    Mar 2005
    wow ok this makes sense.. but is that the audigy video card?
    in the 5.1 surround it uses 3 of them head phone jacks. to which colors does that go to?
    thats how i want to do this.. screw a head unit. will leave more room for a touch screen
    and that 5.1 setup.. wuts the sound quality like on that? worth it?
    thnaks for the pics!
  3. #93
    Jan 2002
    Long Island, NY
    The 3 headphone jacks (1/8th) you need to convert to RCA's somehow to plug into the amp as described above. After doing so, you should have 3 pairs (6) RCA outputs.
    1 jack goes to front left and front right.
    1 jack goes to rear left and rear right.
    1 jack goes to center channel and sub. ( I didn't connect the center channel RCA since I don't have one (yet!))
    I'm not sure about the colors cause the ZS series have colors but the USB NX has black 1/8th (non-color coded) but you can see the description next to each 1/8th jack. Like it shows you if it's side etc..
  4. #94
    Mar 2005
    hmm ok kewl so i need an ok audigy card.. any in the under 100 dollar range that willw ork?
  5. #95
    Jan 2002
    Long Island, NY
    Creative Labs Sound Blaster Audigy2 NX External USB Sound System, Model "SB0300" -RETAIL
    http://www.newegg.com/app/viewProduc...102-167&depa=0
    NewEgg
    $85 + $5 fedex shipping.
    This is what i have under my backseat, and run to my amps.
    See it in the picture?
  6. #96
    Mar 2005
    ok so i need 6 channel audio output? is that right? if so do most mobo's not come with that. or do i need more then that. i came cross this mobo.. was wondering..
    http://www.newegg.com/app/viewproduc...131-460&DEPA=0
  7. #97
    Jan 2002
    Long Island, NY
    Generally, onboard sound does not sound as nice as a PCI or USB addon.
    Many people said once they replaced the VIA M10000 with a USB soundcard, it sounded 10'xs better.
    Also, if you run a USB soundcard, you can just run a USB cable by where you amps are so you don't need to run long RCA cables out of the 1/8th jacks to the RCA inputs on the amps. (More wiring....like I dont have enough )
    Also some people that had groundloops and interference from the car altenator said it fixed those problems.
  8. #98
    Jan 2002
    Long Island, NY
    Also, your mobo looks as though it will draw alot of watts.
    How do you plan on powering it?
    In the car, you want to try to pull the least watts, so you don't need a huge power supply.
  9. #99
    Mar 2005
    ahh ok ,makes sense. hmm
  10. #100
    Mar 2005
    kansas
    If your ears work properly and you spent some hard earned cash on some nice speakers then dont just use a y splitter. It is a very easy way to connect to an amp but not a nice sounding way. Most sound cards arent built to output a 13v signal. Plus, following this example, if you want to connect 2 amsp for subs and components then you need to y split twice. Follow PPGT94's diagram, but instead of going straight to the ano i would but in and OVERDRIVE signal prcessor/booster from AUDIOCONTROL. Then conect to your 4 channel amp. And if you want subs and components then use a 2xs or 24xs crossover by audiocontrol after the overdrive unit. This will give you 2 sets of pre outs. A high pass for the components and a lowpass for your subs. All of these audiocontrol components i have found on ebay at very reasonable prices. And select other online retailers. Sounddomain doesnt have them cuz they dont know squat about car audio. And if you have further questions let me know and i can diagram it out for you
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. PC To Car Speakers
    By eCar™ in forum General Hardware Discussion
    Last Post: 08-17-2008, 01:35 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  5. Another pc sound -> car speakers question
    By Juz in forum General Hardware Discussion
    Last Post: 10-17-2002, 12:47 PM
