Page 11 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 101 to 110 of 148
Thread: HOW TO: Get sound from PC to Car Stereo / Amp
  1. #101
    Newbie Warpath's Avatar
    Jan 2005
    West Virginia
    Hmm, could also use an EQ. Mount it in the dash or where ever. One set of RCA's from the soundcard to the input of the EQ. The EQ will then give you 3 sets of RCA outputs...Front, Rear, Subs. This will also give you a good signal boost and much easier to tweak.
    Wire Diagram - EQ, 4ch amp, Subs and carputer
    Current Progress
    Fujitsu Stylistic 3400 TabletPC
    Win2K
    Wireless Keyboard
    300w Inverter
    40gig External USB Hard Drive
    FM Modulator
    My Carputer
  2. #102
    Jan 2005
    Please help me. I tried using the 4.1 setup for my carputer and I can't get it to work. I get no sound at all. I used a HP 2.8 Ghz computer and a Rockford Fosgate Punch P4004 4 channel amp. I've tested my sound card and my amp. They work fine, but they aren't working together. What else can I check? What am I missing? I definetly don't want to have to use a HU. Thanks in advance for your help.
  3. #103
    did you try setting the gains?.. most likely you need a line driver to boost the signal of the sound card so it works with your amp. your soundcard probably doesnt put out enough power for the amp.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  4. #104
    Mar 2005
    Seattle, WA
    Visited my local Car Toys today to check out subs for my audio setup, told the sales guy what I was doing (carputer and splitter to RCA/sound card direct to amp), and he highly advised me against it. Some tech jumbo I can't recall, but something about it not having good sound quality, degrading the speakers, and causing the speakers to eventually send feedback and damaging my carputer. He advised me I was better off using an aux-in on many of the HUs he sold so that this wouldn't happen.
    Any truth to this, or just the standard salesperson scare-tactic?
  5. #105
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    while im no expert, im pretty sure its your usual salesperson scare tactic. if you check many other projects around here, many of them are headless and go straight from the carputer to the amp.
    Your everyday carpc geek and tech guru at your service. *bow*
  6. #106
    yes he wanted you to buy a stereo.. what you need is a line driver =P
  7. #107
    Jan 2005
    Quote Originally Posted by miztahsparklez
    Where can I get a line driver? What specs will it need? Is there a specific brand or model? Will using a different sound card work? If so will a usb soundblaster do the job? Thanks so much for your help.
  8. #108
    Jan 2005
    Warren, Ohio, USA
    id try to run straight from the carputer to the amp without a line driver. nothing should be damaged, and depending on the sound card, it should be able to provide enough voltage for an amp to be able to work with it.
  9. #109
    Jan 2005
    Quote Originally Posted by Vchat20
    I've tried it. It isn't working. I think you have me confused with Song0330. I'm the one that is running straight from my sound card to my amp, with no success. Will switching to a usb soundblaster solve my problem? Do I need a line driver?
  10. #110
    moahdib's Avatar
    Jul 2000
    Get line drivers here:
    http://www.logjamelectronics.com/linedrivers.html
    I think the PIE is good enough for your purposes... I am getting one too. Sound from my laptop to the head unit line level input is too low for my taste. =)
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. PC To Car Speakers
    By eCar™ in forum General Hardware Discussion
    Last Post: 08-17-2008, 12:35 PM
  3. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  4. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 02:10 AM
  5. Another pc sound -> car speakers question
    By Juz in forum General Hardware Discussion
    Last Post: 10-17-2002, 11:47 AM
