Page 15 of 15 FirstFirst ... 56789101112131415
Results 141 to 148 of 148
Thread: HOW TO: Get sound from PC to Car Stereo / Amp
  1. #141
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    Get horrible sound when hooking up computer to radio
    IM getting some bad sound when I plug the rca's from the computer into the aux inputs into the radio. I had the same problem when I tried to use a playstation. From what I read, there shouldn't be any problems, but it sounds horrible. I can hear the music, but it has some static type sound, but something a little different.
    Anyone know what this is or how to get rid of it?
    thanks for the help
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
  2. #142
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by ppgt94
    Not if it's done through software. Most surround sound cards offer many options to up or down-mix channels. It doesn't change any ohmage. I'll look for a screen shot to try and visually explain what I'm talking about.
    I know, but I'm talking about what the other person is trying to do. Bridge the center channel off the front left and right speaker outputs on the amp.
    He's trying to do it physically. Yes that will alter the ohms.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  3. #143
    Apr 2005
    lancashire
    I have read this thread and think I understand what I need to connect my pc to the speakers with the HU.
    front lineout of HU to linein on pc (speakers disconnected from HU)
    pc lineout to amp
    amp to original Hu speaker connection (front and rear speakers)
    now I know I need various adaptors, leads etc and can work out what I need when I get the amp, which is where I come to my question.
    What sort of amp do I need? , I know absolutely nothing about them. I have googled all over the place and I am now just confused
    what do all these terms like channels, cross over, mean. can somebody put me out of my misery by advising me of what type of amp I need or point me in the direction of a web page that explains amps in terms that an idiot like myself can understand
  4. #144
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    im confised about what your trying to do, you just need a 2.5" to phono lead, 2.5" eng goes into speaker out connection on oc, and goes into aux in on your headunit, then, if you want to go to an amp, same as you would withount the pc.
    edit:
    also, channels are how many different feeds the amp has, eg if you have 2 channels, you have to feeds (left and right) 4 for front and rear left and right, mono for subs.
    bridge is when you take an amp with multiple chanels and group channels to give you more power, eg if you have a 2 * 400, you can bridge it to be 1*800 to run a sub.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  5. #145
    Apr 2005
    lancashire
    As I said, the wiring bit I can sort out, I just dont understand what type of amp I need, 2, 4 or more channels, cross over ( what does this mean) 100, 200 etc watts output. I just want to connect my radio to my pc and then onto the speakers in my car. nothing fancy, loud etc. I know nothing about amplifiers, for instance, how do you control the volume - do they have controls like radios?
    so if someone could advise me what sort of amp I am likely to need, or point me to the dummies guide to amps, I would be very grateful
    ps dont say or I have tried and just got confused
  6. #146
    Apr 2005
    UK
    who do you want to go hu > pc > amp?
    it would be a lot easier (as you dont need special cables / have to cut stuff up) if you go: PC > HU > AMP.
    they have a gain control, you set this set this then your your input (hu or pc) to control the volume.
    you can get a 2 channel, you have left and right audio, if you get 4 channel you have front left, front right, rear left & rear right.
    as for the watts, you need to find out what your speakers are, but i would think 200 would be enough if your using stock speakers.
    Type-R Mini
  7. #147
    Apr 2005
    lancashire
    Quote Originally Posted by dan__wright
    well it would be easier if there was a sound input on my radio, all there is an input for a cd changer and nobody seems to have the required adaptor
    right, so every speaker needs a channel. What I do not understand is, if the sound is recorded in stereo, what comes out the rear speakers? I mean its not as if we are talking surround sound here.
    The other question that springs to mind is, if I get a 4 channel amp, are the channels both in and out or two in four out or four in two out. What I am really trying to say (and making a pigs ear of it) can I use a 2 channel amp connected to the front and rear speakers or do I have to use a 4 channel one.
  8. #148
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Thread sifted...needs more cleaning
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. PC To Car Speakers
    By eCarô in forum General Hardware Discussion
    Last Post: 08-17-2008, 01:35 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  5. Another pc sound -> car speakers question
    By Juz in forum General Hardware Discussion
    Last Post: 10-17-2002, 12:47 PM
