And now my own question. What is the maximum current the stock wiring can provide. I don't expect my M1-ATX supply to draw more than 5 amps and most car head units have a 10amp fuse, so surely I can run this off the stock wiring?
FYI: A keypower 250w PSU uses 37 amps... 60% efficiencyOriginally Posted by RFMan
The point of this thread is NOT to ask questions! Run wires to your battery.Originally Posted by Lum
Is this where the witty comment goes?97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Heres a few different wire size guides..
http://www.skingco.com/portable_powe...size_chart.htm
This is one from the 12volt source.. it is WAY OFF, but take it with some salt:
http://www.the12volt.com/info/recwirsz.asp
(says 100 watts rms is 16 amps!... 16a x 12v = 192watt, so that means your device is 50% effecient?!? )
ALWAYS use larger wire than needed. This will minimize wire temperature (help reduce risk of fire), minimize the voltage lost (if maxing out 8 gauge you may have 12.3v at the end of the wire with the engine running, and by only replacing it with 4 gauge can go up to 13+v).. (more volts = more power from your amps!)
99 ram 5.9 turbo
P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
I would just use a factory wire-harness found at any car audio shop or circuit city/best buy type store like Lum said...because the wires are already labeled.
King
this might be handy. If you want to cheaply wire four speakers up to a two channel amp then simpy run four wires (two sets of twin) from your amp to the front and then have a Left +/- and a Right +/- then wire the two left hand speakers to one set and the two right hand speakers to the other thus:
sorry if it's obvious but it saved on running lots of cables.
Current Honda Accord Aero Deck install
http://mp3car.com/vbulletin/showthread.php?t=78717
96' Laguna install
http://www.mp3car.com/vbulletin/worklogs/45365-96-renault-laguna-project.html
how are you guys connect the 4-12 gauge wires to your power supply?
the wires on my m1-atx are very thin (i'm guessing 16+ gauge) , are you just connecting the larger guage wire to the 16+ gauge wire?
thanks.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
I can tell you that no one does that. In order to realize any effects of using larger wire, you have to use larger wire all around.
Most likely the 16 gauge wire is unsoldered by reheating, and then the new larger wire is soldered into its place.
At least thats what i plan on doing
Originally Posted by Dragonknell911
I think this is a misunderstanding. I'm not going to get into a long technical response, but for short distances, gauge isn't a big issue. If the device harness supplies a 1 ft 16gauge wire, you won't see any benefit to cutting the harness shorter as the device doesn't require it. Now if you were running a 1500w amp, 16 gauge wouldn't cut it for any length of course.
The point being, 4 gauge for 20ft split to 8 gauge for 1 ft is no different than running 4 gauge to each device unless the device requires more than 4 gauge to begin with.
- 2.53ghz, Maxtor 200GB, 1gig RAM, ASUS miniATX w/ HD Audio & PCIE
- 150w OPUS, DVD, VideoMate TV/PVR/FM, GPS, Wireless-G, Antec Aria case, RoadRunner
- JL Audio 450/4, 1000/1 - XR650CSi, 12w7, Lilliput 7" touchscreen
heres a question, I have 0 gauge wire running to the rear of my truck for my amps, could I tap into this for power to my 150w Opus? If I can, how would I go about doing it? sorry for the basic but important question
