Moved non-FAQ posts to LCD/Display forum here.
What if you are using the VIA MII motherboard with LVDS controller option?
I played with LCD's a little bit a my last job and providing you can assign pins with the LVDS controller couldn't it be plugged directly into the board?
Here is the controller I'm talking about. There is another one for 24bit panels
http://www.logicsupply.com/product_i...roducts_id/420
Want to:
...if your bios supports the type of panel you have, AND you can get the pinnouts, AND you can make or get the cable, then yes, you can run a lvds screen straight off the lvds motherboard....
EarthLCD also carries the VGA cards and boards.
Michael
holy thread-necro batman
Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
Hello I have a compaq presario 1500c laptop. The LCD inside is a Torisan TFT TM121SV-02L01B. I would like to get the controller that plugs into the back of the LCD to connect to the laptop or make it have a VGA connector on the other end if you could anyone help?
Let me help you out here,Originally Posted by airwebb18
FAQ: Using a Laptop LCD as Your Car PC Screen
Michael
if u have a lvds interface on your lcd( have a look on the lcd specs) then u can easy extend the wires, but if it's ttl signal(x bit color signals were x= 4,6,8 bits) then extending is much more difficult..may be imposible.
Another method to figure it out wich interface are u using is if u have twisted wires..then most of are lvds...if it is a flexible ribbon...then it's ttl
Does anyone have an idea about using an apple ibook LCD? I want to connect it to a mac mini installed in my scion Xb. The mac mini has a s-video out. so my questions is, can I convert the wiring from the ibook LCD to a S-video IN without using anything else other than the S-video OUT on the mac mini? thanks
jim
no...
