Results 21 to 30 of 36
Thread: FAQ: Getting Rid of that Whine or Buzzing Noise in Your Speakers
  1. #21
    Newbie ErikArmbrust's Avatar
    Apr 2005
    Nebraska
    Emi
    A lot of times there might be sinusoidal EMI interference caused by an inverter that unshielded RCAs are run close to. DC power also causes EMI when it's not shielded. I guess, I'm saying that if you can't route power cables anywhere but next to RCAs, just get shielded RCAs.. which are more expensive, but it eliminates the need to separate cable routings. It increases sound quality and magnitude very well.
    Finished carputer:
    2000 Black Blazer
    Construction/ finished/ before
  2. #22
    May 2005
    What if im not comfortable drilling into the body? What are some other good grounding points? currently I have my screen and headunit grounded to the same OEM Radio Harness ground. with A LOT of RCA cables running around it, and of course getting a fair amount of whine, a lot more when the laptop runs on battery instead of the inverter. It also comes and goes depending on where I am and how fast I am going (or maybe I'm turning the stereo up too high and cant hear it anymore.)
    I have a 98 Honda accord if anyone has the same and can recommend some good ground points that dont involve drilling.
  3. #23
    Dec 2005
    Where the belt or seats are fastened are usually good spots.
    -Ko_deZ-
  4. #24
    _
    Mar 2004
    Little Elm, Texas
    where belts or seats are fastened are usually NOT good spots.
    You are better served to create your own ground. This is because you need contact to BARE metal. Using the bolt holes of a seat is not a good idea for a few reasons.
    The threads for the bolt hole are usually covered in paint and have a bunch of garbage in them. This will prevent you from getting a solid ground.
    Usually when you ground to a seat bolt, you're on top of the carpet. As such, you're only relying on the contact with the bolt, which then makes contact through the threads only for a ground. This is not a solid ground, no matter how you look at it.
    Drilling into the car in the right place will not devalue the car in the least. Do it in the trunk under some carpet and you'll be fine.
    Don't be scared to drill a small hole in the car. It's a needless worry.
    Jan Bennett
  5. #25
    Dec 2005
    Yes, those ARE good spots. There are several reasons for it. There is NOT paint inside the threads. Having that would be plain stupid, as the strength of the threads would be very poor, as well as them being broken every time you fasten/unfasten them. You do know what happens to your cars paint if you scratch a key along its side, right?
    You will have to connect the ground to the metal parts of the car, that is true. There are some parts of the car that are not supposed to come loose in event of a crash, most notable is the seatbelt, and the seats. These are fastened in places that does not give in, and I can assure you that none of those places are disconnected from the chassis by using paint. That goes against all common sense.
    Usually, if one want a good ground-connection, one removes paint to reveal bare metal on both sides of a metal plate, and put a bolt trough it, holding the whire. In a car, you have dozens of those places. Also, the you don't use a nut, but threads that are welded to the metal of the car, meaning that ever bit of thread helps to give a good grounding connection.
    If you are still uncertain of how good the grounding is in the bolt, connect a multimeter and measure the resistance from the cars battery negative to the bolt that holdt the seat(-belt). Compare that to bare metal that you find somewhere.
    Drilling a hole in the wrong place can give you condensing problems, and revealing bare metal in places that is supposed to be painted will run you the risk of rusting. Maybe not a big problem everywhere, but a unnessesary risk. I know a couple of professional audio builders (some that has won national DB drag championships, and they allway use the seat-belt bolt for grounding. It does not come much better than that.
    -Ko_deZ-
  6. #26
    _
    Mar 2004
    Little Elm, Texas
    I will disagree with you and with using a seat bolt as a grounding point....and we've won 2 world titles in Sound Quality....where the quality of the install is actually judged...unlike in DB drag or any SPL comp for that matter. I'd also like to note that our vehicle consistantly scores the highest in install in the DIVISION, not just our class. Getting a 99% perfect score at finals is not easily done, and is very rare to boot.
    And yes, we are the installers.
    The point of my post was this: consider where you are trying to ground. Relying on a ring terminal that's going to give you 1/8" of contact to that bolt on the interior sides of the terminal is NOT a good ground.
    Sanding away the paint and using the same bolt (as long as IT also has the paint removed) IS ok. No matter how you look at it, over time, grit and grime gets into the threads, which lessens your continuity.
    I'd also like to note that there's a reason that major chains make it a standard to NOT use those locations for grounding.
    Jan Bennett
  7. #27
    Dec 2005
    You have som experience in the field. That is good. Makes the discussion more intersting =)
    I can partially agree with you on the seat-bolts. You should sand down the area first. That should go without saying really.
    As to the belt fastening points, I see no reason to not use them. From an electrical point of view (i am an electronic engineer after all), given that you sand down the area, and don't use a painted bolt (which I cannot remember to have encountered in any of these two positions), should give you as solid a ground as you can get in a car without welding or soldering.
    Given time, rust and corrotion(or whatever that stuff that piles up on you battery poles is called in english) can make the connection weaker, but on these places things should be fastened so thightly that the forces forcing the threads together should stop any grit and grime from getting between them.
    I can se a couple of resons not to use them, seen from a major chains point of view. If they mess up, and the seat belt or seat loosens in a crash, then they would be in for a major lawsuit. So better keep your hands off them. As long as you use common sense, the belt and seat fastening points should do just fine for grounding.
    I do see the problem with painted bolts. Does cars tend to use that now? I have never seen that in the mentioned places before.
    Getting that world championship is a lot of work, and believe me, all due respect for that. I am a bit curious about the US definition of world champions though. It seems to me that most of these world champion titles are won without much outside competition. Some US sports also seem to do this, even though only US teams are part of the competitions. Is that just a misunderstanding from my part? I do realize that "outsiders" are allowed to compete, but give that US has less than 10% of the worlds population, are more than 50% of the competetors from outside USA? Some input from one who actually has competed in these competitions would be very interesting, if you don't mind =)
    I know that European competitions usually allows outside competetors, but the titles are usually European Champion, or German Champion. It might seem a bit weird that a englishman can be German Champion, but it happens sometimes. After all, a world champion is also the champion of France, Germany, Greece, Italy, Russia, India and China.
    -Ko_deZ-
  8. #28
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    From my experience, do not have long ground runs. The recommended run should be 6 feet and under. On my first install it was double that. The system not only suffered from engine whine, but also was very slow. On the new install the ground is only 7 inches. Also do not use cheap ground loop isolators, they will muffle your sound, especially ones from Radio Shack. I went with one from BEST BUY from a company called Install Edge. It promises to not muffle sound and add a 3db gain, and it does as advertised.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  9. #29
    Low Bitrate lor109's Avatar
    Mar 2004
    Quote Originally Posted by HiJackZX1 View Post
    Hijackzx1,
    Does your 08' eby701 cause any noise in your system? The reason I ask is my PC is perfectly silent until I turn on the EBY701. With it on there is a high pitched whine. It is definatly worse when first starting the monitor in the morning. Calms down after 10 minutes or so, but never goes completely away. I suppose it could be the close proximity of the Screen to the Motherboard which is also installed in the dash, but I didn't have this problem with my previous Lilli. Everything is grounded to one point with only about 12 inches of wire.
    Any help would be most appreciated.
    Nathaniel
  10. #30
    Jul 2007
    Miami
    Quote Originally Posted by lor109 View Post
    Hijackzx1,
    Nathaniel
    I honestly dont know. I am in the process of completing the install, and i sure hope not, because I have 3 EBY701s in my install. None of the screens will be powered by the PC, but rather a relay connected directly to the 12v+ and ground lines, with the ACC 12v+ being the activation switch. I decided on this because i did not want to bogg down my system in an way. Also i did it this way since all screens have there own regulators and fuses. Oh gosh you have me so worried now. Also as a note, my PC is no were near the screens.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Buzzing noise help
    By fletcher5555 in forum Car Audio
    Last Post: 05-30-2005, 07:03 AM
  2. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  3. Buzzing noise when shuttle is plugged in
    By mazda3uzr in forum Car Audio
    Last Post: 12-22-2004, 09:59 PM
  4. More details on my buzzing noise....
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-02-2004, 01:46 PM
  5. noise from rear speakers, please look at video
    By sanbas in forum Car Audio
    Last Post: 09-25-2004, 08:46 PM
