Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 102
Thread: FAQ: Boot directly into your front end
  1. #91
    Newbie alienmanfc6's Avatar
    Sep 2007
    Ashton
    Quote Originally Posted by Maheriano View Post
    I hit Start and then Run and put in regedit and hit OK. But it said regedit is not a valid Win32 application and that's it.
    depending on what ver. of windows you have you might have to use "regedit32" instead of just "regedit"
  2. #92
    Sep 2006
    Cornwall, England
    I have read this thread and a lot of people have said that if you have the registry entry to shell into your front-end, when you run explorer.exe, it only brings up the windows explorer window, not the entire GUI. After playing around with it for an hour, I found that if you boot into your front-end and then edit the registry entry in .....winlogon\shell and enter 'explorer.exe', then run explorer.exe, the full XP GUI will pop up, not just a windows explorer window.
    Because I have programed my own front end in VB.NET, I can write code into it to change the registry entry.
    What I do first when my front-end loads is change the registry entry to shell explorer.exe
    When I click the exit button, it shells explorer.exe, then re-writes the registry entry to shell my front-end, then ends the front-end:
    In the main form load_Load:
    Dim WSH
    WSH = CreateObject("WScript.Shell")
    WSH.RegWrite("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows
    NT\CurrentVersion\Winlogon\Shell", "explorer.exe")
    In the 'exit' button:
    Shell("explorer.exe")
    Dim WSH
    WSH.RegWrite("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell", My.Application.Info.DirectoryPath & "\Vive.exe")
    End
    Vive.exe is the front-end executable.
    This seems to work fine, hope this helps some people
  3. #93
    Sep 2007
    West Springfield, MA
    After reading this thread, it seems there are more ways to do this then I thought. I saw someone mentioned something about writing a script with AutoIT. If I just wrote a script that made RR open, and put the .exe file in the startup folder, would this do the trick? I'm sure this isn't the fastest way, but it would leave explorer.exe as the shell in the registry, which seems to be causing some problems for people when it's changed.
  4. #94
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by blackcobra487 View Post
    After running into countless problems when using RR as shell, I reverted back to using Explorer as the shell and I put RR in the Startup. Now, as soon as windows boot, RR splash screen takes over and RR loads up. Its not as seemless as running RR as shell but it's trouble free and works very well.
  5. #95
    Sep 2007
    ajamils, I noticed you're also an Accord driver. I've got an 03 sedan. I think it's funny how we both went with a mo-co-so case under the drivers seat.
  6. #96
    Sep 2006
    Richmond, Tx: USA
    Well, I debated between a lot of different places and cases but only under the seat and that case made sense to me
  7. #97
    Sep 2008
    hi there!
    i just set up an nlite XP installation (used the "safe ini") on VirtualBox and when roadrunner is set as shell windows is somewhat stuck on the welcome splash screen at logon...
    it just takes quite some time for roadrunner to finally show up... it's quicker when i start it as an autorun...
    is there anything i could do about it?
  8. #98
    Sep 2007
    Quote Originally Posted by caughtfire View Post
    hi there!
    If it's quicker to leave RR as autorun (I'm guessing you mean you put it in the startup folder), why not just leave it that way?
  9. #99
    Sep 2008
    ya you're probably right... it's just that to me it looks nicer to not have the desktop shown up first... but that's ok i could live with that i guess
  10. #100
    Sep 2007
    I didn't think of that at first. It would be nice for the desktop to not show up. But I feel speed is more important.
  1. Why do we need car Front End software?!
    By nijel in forum Software & Software Development
    Last Post: 04-09-2006, 12:50 AM
  2. Recomend a front end.
    By bigmac999 in forum Software & Software Development
    Last Post: 05-03-2005, 02:24 AM
  3. Roll your own front end
    By wysocki in forum FrodoPlayer
    Last Post: 05-01-2005, 10:46 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 08:33 AM
  5. cool front end software
    By liquid_smoke in forum Software & Software Development
    Last Post: 09-02-2003, 12:23 AM
