Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 102
Thread: FAQ: Boot directly into your front end
  1. #21
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    for frodoplayer, how much time does this save during booting. Right now, i have frodo on autolaunch, and it is 5sec opus delay +8 sec bois + 22 sec windows +8 sec services after my destop loads, before frodo opens up, then 17 seconds before frodo plays, I hoping that this can reduce that 8 seconds between when i see my desktop (by getting rid of that) and by the time frodo loads.
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  2. #22
    Aug 2005
    Has anybody had internet explorer not load web sites when going directly to a front end? I'm using Road Runner and when going directly to the frontend i can't access the internet.
    hmmm......exiting out of Road Runner and going in to frodo player allows me to access the internet and going back in to road runner I can now access the internet.
    I did hit "work off line" earlier, but unchecked it right after hitting it perhaps it has created a setting somewhere? Tried uninstalling roadrunner and reinstalling it, but still no internet when booting directly into RR.
    Doesn't work when booting directly into Frodo player either. I could have sworn I was going on-line before when booting into a front end.
    Yeah I guess hitting "work off line" farked something up because I just ran a test on my desktop and had no problem going on-line after booting in to RR. Oh well I had planed on reinstalling windows on the CarPC anyway as I've only had it running to test out various programs and such.
  3. #23
    FLAC alti's Avatar
    NY
    Alternatively you can also run Carshell as your shell. Carshell will run any applications that you have in your startup folder (including front ends) and reduces boot time. (usually by a few seconds) You can also run your other applications from it and it works as a basic desktop that is easier to use in the car, and provides an easy checkbox setting to switch between explorer and carShell as shell.
    More information here
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #24
    Aug 2005
    sounds interesting I'll try that out today after I get back from class
  5. #25
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Bugbyte
    If you are using a front end that allows you to launch an application, you can put explorer.exe as a program that can be launched. If you need to access explorer, you can launch it from the front end.
    Newbie question:
    What is the command line I enter into FP for explorer?
    and what is the command line for Calculator?
    What's the easiest way to find these command lines? IE: when I right click on properties for the calculator, I can't seem to find the command line.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  6. #26
    FLAC alti's Avatar
    NY
    %windows%\explorer.exe <-- if you are useing xp and did not change the installation dir then it is c:\windows\explorer.exe
    %windows%\%system%\calc.exe <--- again it the above is true the path will be C:\WINDOWS\system32\Calc.exe
    The easiest way to find them i suppose would be the search function "by files or folders", but you can also just browse in explorer to look for them. A another way is to right click on a shortcut to the program and click on the find target button, it will open a explorer window to the path the file is located.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  7. #27
    Raw Wave tj!2k4's Avatar
    Oct 2004
    ^ think you meant to say %windir%
  8. #28
    Jun 2004
    South-Central PA
    Hmmm, tried both of those. Both end up in FP as "false", must've typed them wrong or something.
  9. #29
    FLAC alti's Avatar
    NY
    Quote Originally Posted by tj!2k4
    opps
    Muldrick, if your file system is setup like above and you are running XP they *should* be there.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  10. #30
    Oct 2004
    fp may not accept system variables like that.. you may have to specify the full path.
  1. Why do we need car Front End software?!
    By nijel in forum Software & Software Development
    Last Post: 04-09-2006, 01:50 AM
  2. Recomend a front end.
    By bigmac999 in forum Software & Software Development
    Last Post: 05-03-2005, 03:24 AM
  3. Roll your own front end
    By wysocki in forum FrodoPlayer
    Last Post: 05-01-2005, 11:46 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  5. cool front end software
    By liquid_smoke in forum Software & Software Development
    Last Post: 09-02-2003, 01:23 AM
