Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 102
Thread: FAQ: Boot directly into your front end
  1. #41
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    well the batch file i ws referring to was to apply changes to an EWF system, as I stated.
    As far as registry files, just export the explorer one that's default, then create the one as described in the first page of this thread and export that.. now you have 2 registry files you can click back and forth between and reboot to change the shell.
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
  2. #42
    Jul 2004
    Here is what my reg file to change the shell to Frodoplayer looks like:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "Shell"="C:\Program Files\Frodoplayer\Frodoplayer.exe"
    But it doesn't work. The shell stays as explorer.exe. Do you know why?
    My other reg file changes the shell from Frodoplayer back to explorer.exe no problem...but I have to manually modify the registry to change the shell to Frodoplayer...
  3. #43
    Feb 2005
    %systemroot% is the 'default' for all NT boxes (NT4/2K/XP/2K3) while %windir% is a nice little add-on in most installations for application calls etc...
    Quote:
    Originally Posted by tj!2k4
    ^ think you meant to say %windir%
    opps
    Muldrick, if your file system is setup like above and you are running XP they *should* be there.
  4. #44
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by Jackboot
    I went and tried to make a .reg file so the shell could be easily changed. For some reason, the registry seems to not allow the shell to be changed via a .reg file. Even when I'd manually change it (which it would take) and then export the key, the registry would not make the change. Perhaps its some kinda of safety within Windows to prevent this from happening.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  5. #45
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by d_sellers1
    Derek
    Create the .reg in safe mode.
  6. #46
    Jul 2004
    Quote Originally Posted by Sonicxtacy02
    Without using safe mode, windows will allow the .reg file to be created. The problem isn't *creating* the .reg file. The problem is that when you run the .reg file the shell doesn't change - it stays as explorer.exe!
    @d_sellers: You obtained the same results that I did. I agree it must be some sort of built-in protection against a virus changing the shell to something unusable.
    Any other ideas?
  7. #47
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Quote Originally Posted by muldrick
    Ok, I had done that, just never tried it. After I had entered it into apps. it kept (keeps) saying "FALSE-FALSE" after the command line. But it works fine, added a bunch of other stuff too. I like this
    Thanks for your help.
    The FALSE - FALSE indicators point out the status of the 2 checkboxes.
    So "Pause Frodoplayer = FALSE" and "Minimize Frodoplayer = FALSE"
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  8. #48
    Mar 2002
    Austin, Texas
    Any other ideas?
    A friend of mine has a program that he was showing me that replaces the windows shell with a more Widgets-style shell. The neat thing about it is that it included a small program that easily allowed for the shell to be changed back and forth. Now the problem is, I don't remember the name of the progarm that he was using. I've been meaning to get back with him on it but I haven't seen him around (which is bad because he doesn't live very far).
    Derek
  9. #49
    Newbie MV54's Avatar
    Nov 2005
    London
    A friend of mine has a program that he was showing me that replaces the windows shell with a more Widgets-style shell. The neat thing about it is that it included a small program that easily allowed for the shell to be changed back and forth. Now the problem is, I don't remember the name of the program that he was using. I've been meaning to get back with him on it but I haven't seen him around (which is bad because he doesn't live very far).
    Derek
    I'm trying to find a way to load up a few programs on windows start; X Port which clones my serial port, gatso hunter (speed camera detector) and RR.
    I have them all loaded from a .vbs file atm, but it won't work when I link to that as the shell.
    Then I thought I'd try carshell- but I can't seem to d/l it from anywhere! CarShell v2
  10. #50
    Mar 2002
    Austin, Texas
    Quote Originally Posted by MV54
    You know what may work better than the .vbs? Try making an AutoIt script. AutoIt scripts can be used to automate damn near anything. Unfortunately it may be a pain in the *** to get it to work just right. You can get it from here. It's available in an installable version and standalone. Plus, the script file (.au3) can be saved as a .exe using the included .au3>.exe converter.
    Hmmm, I wonder if a script can make the change... AutoIt v3 does have registry reading (not sure about writing) capabilities. I'll look more into it and see what I can find out. Perhaps then we can get around the .reg shell protection.
    Derek
  1. Why do we need car Front End software?!
    By nijel in forum Software & Software Development
    Last Post: 04-09-2006, 01:50 AM
  2. Recomend a front end.
    By bigmac999 in forum Software & Software Development
    Last Post: 05-03-2005, 03:24 AM
  3. Roll your own front end
    By wysocki in forum FrodoPlayer
    Last Post: 05-01-2005, 11:46 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  5. cool front end software
    By liquid_smoke in forum Software & Software Development
    Last Post: 09-02-2003, 01:23 AM
