Just because explorer.exe is not running does not mean that nothing else is going to run. I have RoadRunner set as my shell and my Bluetooth module, USB GPS, and Buffalo wNIC adapters all load with no problems. I also run iGuidance within RoadRunner along with SkinBedder and iGMon. I can also use Firefox to access the internet when I am connected wirelessly. I can also manually start Explorer.exe by launching it from within RoadRunner. So again, explorer does not need to be running to do what you've described.Quote:
Originally Posted by chewEboy
EDIT: To answer your question: You should be able to set you front-end up as your shell and have the front-end loaded your desired programs.
Derek
