Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 102
Thread: FAQ: Boot directly into your front end
  1. #81
    Feb 2007
    PA
    i didn't read through all 6 pages, but here's a free program that will allow you to add anything to start up quite easily...
    http://www.mlin.net/StartupCPL.shtml
    PM me if you can't get it working
  2. #82
    Newbie pasan's Avatar
    Mar 2007
    Sri Lanka
    How to boot directly in to Winamp using windows 98?
    Pasan...
  3. #83
    Elsewhere
    Put a shortcut to WinAmp in the Startup program folder.
    How about the Wiki?
  4. #84
    Mar 2007
    Sri Lanka
    Quote Originally Posted by darroj View Post
    Mike Lin's Home Page
    Thanks man. Its working. and very easy
    Pasan...
  5. #85
    Mar 2007
    Sri Lanka
    Quote Originally Posted by DarquePervert View Post
    Thank u very much for the fast info
    Pasan...
  6. #86
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    what about autoit, i use simple scrypts to make the changes to the registry from my skin(ROAD RUNNER SKIN)this way if i need my full desktop i can go back to explorer easily.
    Quote Originally Posted by ajamils View Post
    I believe that there Explorer has something to do with apps that reside in taskbar because Xport resides in taskbar too.
    We need to find out a way to load these things with road runnner.
    road runner is capable of launching any program when starts, for example i use this to launch xport. RUN;C:\xport\xport.exe RRconfig tool has this option and writes this info to the rr.ini, but for more info about this,go to the Road Runner corner.
  7. #87
    May 2006
    Calgary, Alberta
    I hit Start and then Run and put in regedit and hit OK. But it said regedit is not a valid Win32 application and that's it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  8. #88
    Jun 2006
    Chetwynd, British Columbia, Canada
    I just thought I would share my current solution:
    In regedit navigate to:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Run
    You should see a familiar list (if you play with your boot settings a lot). It is the list of programs that windows loads during start up.
    Go to edit, and create a new string value. Name it whatever you want (front end name most likely) and then for the value, put the path of the program you want to boot in quotation marks.
    ex. "C:\RoadRunner\RoadRunner.exe"
    When you restart your computer the program will then load on startup. Granted you will see your desktop for around 1/2 second but I found this loaded faster than changing the shell to Road Runner.
    It also saves you from any sort of trying to launch explorer when you want to return to desktop. (I was launching explorer and only the My Documents window would appear)
    Hope this hasn't already been exposed!
  9. #89
    Aug 2004
    Germany
    I have a problem. I'm running TinyXP_rev05 and changed the shell as described on the first page. I guess it works as it should:
    I changed the registry key to start RoadRunner. Now when I reboot RoadRunner runs as shell. When I exit RoadRunner it automatically restarts. So far so fine.
    But when I want to shutdown the computer, RoadRunner quits and then windows tries to restart it. But it can't because the shutdown-procedure is initiated. So a Windows message window appears saying "The application failed to initialize because the windows station is shutting down". Why does the system do that ? When I shutdown it obviously shouldn't restart the shell. I also set "AutoRestartShell" to 0, which doesn't make a difference.
    1. So, how do I stop windows trying to restart the shell-program when shutting down ?
    2. Not that important, but I'd rather like RoadRunner not to restart, when I quit it.
    EDIT:
    Hm, I guess this question fits better in the RoadRunner forums, so I posted my question also there. If that's against the rules I'll delete this post asap. I just still left it in this thread, because that's a problem which didn't appear in this FAQ before, and I guess this could be helpful for other users.
    EDIT2:
    Problem solved...more or less. After changing back from minilogon to winlogon this problem doesn't occur anymore. Anyone got a clue why it's not working correctly with Minilogon ?
  10. #90
    Autologon problem
    I'm running frodoplayer and I have it set to run as my shell. I edited using tweakui the autologon files to automatically log me on and for some reason after I edit the files I restart and it works fine then I shut down the computer and come back the next morning and theres the stupid login screen again. Whats the deal with that? I've done everything that the guide tells me to do but I think its just not saving it in the registry after a complete shutdown. Any suggestions.
  1. Why do we need car Front End software?!
    By nijel in forum Software & Software Development
    Last Post: 04-09-2006, 01:50 AM
  2. Recomend a front end.
    By bigmac999 in forum Software & Software Development
    Last Post: 05-03-2005, 03:24 AM
  3. Roll your own front end
    By wysocki in forum FrodoPlayer
    Last Post: 05-01-2005, 11:46 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  5. cool front end software
    By liquid_smoke in forum Software & Software Development
    Last Post: 09-02-2003, 01:23 AM
