FAQ Tutorial: Wire/Pin Mod for Mobile Athlon
(This possibly belongs in the FAQ section, I wasn't sure. Mods feel free to move it needed)
As you all know that the Mobile Athlon Processor runs at its default clock speed of 800 MHz on most motherboard that support the chip. This mod is used to make the motherboard recognize the processor at its correct speed.
How hard is the pin mod?
Is it reversible?
Do you have any pictures of the mod?
I've been asked these questions many times. And to answer them:
Very Simple
Yes
Yes (well now I do)
I was redoing the mod on my board and decided to take some pics (warnig: I'm not the best photographer) and write a small tutorial. Hope this helps the people who are considering the Asus A7N8X motherboard. So here goes.
Oh forgot the disclaimer, This mod is to be done at your own risk. I do not take any responsibly if anything goes wrong. It worked fine for me with out a problem, hopefully you won't have any either.
Tools/Supplies:
- Thin wire, I used 20 awg speaker.
- Tweezers
- Wire cutter (optional) I used my teeth
- Mobile Athlon compatible motherboard.
Process:
1) Go to this site and get your diagram for the wire mod.
http://www.ocinside.de/go_e.html?/ht...md_pinmod.html
Choose socket view and AMD Barton (Make this setting according to the chip you have, either Barton, T-Bred or Athlon XP). Leave the Vcore selection to the default, unless you want to mess around with it. For this example I choose 200 MHz for the FSB and 9.5 X FSB for the Multiplier selection. The multipler selection is based on the chip you are using. When you select the FSB and the multiplier the rating of the chip is displayed in the last box. This should be the same as the chip your are using. Of course you can over/under clock the chip to your liking.
So if you’re following along you should have this diagram.
http://img12.echo.cx/img12/5626/wire1nb.th.gif
2) Take your wire and pull out one strand from it, so you have one really thin piece of wire.
http://img33.echo.cx/img33/5581/picture0051ay.th.jpg
3) Cut a piece off the long wire so that is long enough just to fit in two holes. I cut the wire into 1/4" pieces. Here a picture of the size of the wire I used. Btw, that's a hard drive screw in the picture. (Just for your reference)
http://img33.echo.cx/img33/4066/picture0025oj.th.jpg
4) Take the small wire and curve it into a U shape, using the tweezers at this point helps.
http://img93.echo.cx/img93/4421/picture0069mx.th.jpg
5) Take the wire with the tweezers and position it on top of the holes it belongs in. It’s a little tricky at first, but after a couple of tries, the wire seems to fall in by itself.
Here are the pictures of the final product.
http://img33.echo.cx/img33/9638/picture0017nh.th.jpg
http://img33.echo.cx/img33/4023/picture0031zq.th.jpg
http://img33.echo.cx/img33/9939/picture0040he.th.jpg
If there are any mistakes or if something is unclear, please let me know.
EDIT: Those that are worried about doing the mod, I just like to add that I did a Prime95 torture test on my system after the mod. And after 3+ hours not one single problem or warning.
Keywords: wire mod, pin mod, Mobile Athlon, Asus A7N8X,
