Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 75
Thread: FAQ: How to Wire an OPUS PSU
  1. #11
    Low Bitrate jay_tu's Avatar
    Dec 2004
    Towson
    What about connecting the TS from the OPUS ?
    thanks
    04 Corolla
    Modifications:
    Upgrading pc 99%
    Progress
  2. #12
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Quote Originally Posted by Quattro
    Does anyone know he coloring scheme for the Opus 80w, so I and add that to the diagram as well?
    80W in hand right now.
    Input power Connector
    Uses a 6 pin Mini-Fit Jr Connector (Molex part number 39-01-2060)
    Pin 1 Blk - GND
    Pin 2 Blk - GND
    Pin 3 Red - ACC (Ignition)
    Pin 4 Yel - BAT
    Pin 5 Yel - BAT
    Pin 6 Blu - RMT (Remote)
    Output power Connector
    Uses a 8 pin Mini-Fit Jr Connector (Molex part number 39-01-2080)
    Pin 1 Yel
    Pin 2 Blk
    Pin 3 Blk
    Pin 4 Red
    Pin 5 Yel
    Pin 6 Blk
    Pin 7 Blk
    Pin 8 Red
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
  3. #13
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Great update. I renamed the title of the thread to a more suitable FAQ name
  4. #14
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    @phc, Thanks for the information on the 80w.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  5. #15
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    guess this is the place to post this.
    searched around and cannot find an answer.
    on the IGN, i found a wire, but its most likely 16-14 gauge.
    my question to you is, does the opus draw any power off the ign, or does it just use it as a trigger for a relay?
    hopefully the latter. i ran 8 feet of 10 from my battery, and am grounding in 3 places for everything, but it would be a real crapper if i smoked the ign line from too much draw.
    thanks guys.
  6. #16
    Jun 2005
    for clarification, the yellow line is trigger only, it does not draw any signifficant power. you can run whatever size line you want, as long at its not smaller than what the opus comes with.
  7. #17
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread cleaned to eliminate irrelevant posts.
    Want to:
  8. #18
    Raw Wave justintime's Avatar
    Apr 2005
    Someone should add to this FAQ, how to connect the 10g (suggested) red wire from wiring, to the Opus 14g red wire. Some say use a block distributor, others say solder, etc...
    After posting the correct answer, someone please delete my post (this one!).
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  9. #19
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Quote Originally Posted by seanz0rz
    Just to clarify this, the Ignition wire is a trigger / sense wire only. Meaning, it doesn't have to be any fancy wire. Any circuit inthe car with ignition switching can be used.
    Read more in this thread.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  10. #20
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    what if i want my amp to turn off at the same time as the 0pus. How would you recommend that i connect the IGN line of my APM to the OUTPUT of the 0pus. Where can I tap in so that I won't have a major malfucntion with my 0pus. Can i connect my amp's ign to one of the 12 V leads going to my fan. That way if there is a voltage drop it is only in a minor component like a fan?
    Now, if i do this my amp will stay on until my 0pus shuts off, that way i get 5 more seconds of music?
    Tell me if im wrong
    btw its an 0pus 150
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  1. opus PSU too weak for me?
    By gummybear in forum Power Supplies
    Last Post: 03-04-2005, 01:46 PM
  2. Replies: 5
    Last Post: 02-28-2005, 03:42 PM
  3. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  4. FS: 90W Opus DC-DC PSU and extras
    By EBoundEE in forum Classified Archive
    Last Post: 06-28-2004, 01:54 PM
  5. Opus PSU for Casetronic C134
    By aethernaut in forum Power Supplies
    Last Post: 02-25-2004, 01:19 AM
