Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 75
Thread: FAQ: How to Wire an OPUS PSU
  1. #21
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Moneyfink
    what if i want my amp to turn off at the same time as the 0pus. How would you recommend that i connect the IGN line of my APM to the OUTPUT of the 0pus. Where can I tap in so that I won't have a major malfucntion with my 0pus. Can i connect my amp's ign to one of the 12 V leads going to my fan. That way if there is a voltage drop it is only in a minor component like a fan?
    Now, if i do this my amp will stay on until my 0pus shuts off, that way i get 5 more seconds of music?
    Tell me if im wrong
    btw its an 0pus 150
    Yes, you can connect it to the 12V of the fan or any other 12V lead. It won't hurt the opus. The amp just need the signal to turn on and off.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #22
    Aug 2005
    on that last one, how is there no circuit being completed from the battery??
  3. #23
    Dec 2003
    New York
    Quote Originally Posted by Synth3t1c
    On the second picture, there is a distro block which is being used. All the grounds are being connected to that and then the main ground from the block is connected to the cars chassis. In the first pic the opus is connected back to the battery for the ground, the battery itself it actually connected to the cars chassis for the ground.
    Installed
  4. #24
    Aug 2005
    The first pic also has a big "OR" showing that it can go to the battery "OR" ground to the car chassis.
  5. #25
    Raw Wave tj!2k4's Avatar
    Oct 2004
    yes
    There are two possibilities to connecting the wire to a ground area. You can either run another wire from the batteries negative terminal to the Opus or you can run a negative wire from the Opus and connect it to one of the car’s bolt close to the power supply.
  6. #26
    Dec 2003
    New York
    Quote Originally Posted by Silentbob343
    yeah, the second picture doesn't have the "OR" because it is simpler to connect to the car chassis. You want the ground to be small as possible.
    Installed
  7. #27
    Oct 2004
    Opus 150 Connectors
    Some images of the Opus 150 power connectors w/ part numbers, in case anyone else needs to order these for whatever reason. I got these from Mouser, but the Mfg P/N should be the same wherever you purchase them.
    (I'll be replacing my Opus 150 w/ zootjeff's new 220w psu, and it would be a real pain to remove the Opus' wiring in my dash.. so I'll just use one of these connectors with the new psu.. problem solved. )
    Thanks to zootjeff for locating the P/Ns for me.
  8. #28
    Dec 2005
    Fresno, CA
    I had a question about wiring gauges for the diagram in this post and it was answered here, so I thought I'd post it for others:
    Quote Originally Posted by Quattro
    If you going to be using a distro block like you said then I would suggest you use 4 gauge wire from the battery to the distro block. And from the distro block use 10 gauge wire to connect to the opus and probably 8 gauge wire for the amp (this will depend on the amp, look at your manual it will tell you what wire size to use).
  9. #29
    Oct 2005
    Hope i got this in the right place and no one chew the crap out of me.I read in one of the posts that as a rule of thumb if you need more than 200w of power you should use an inverter, Whay cant you just buy 2 or more dc-dc power supplies and run them in parallel to almost double the wattage output?
    At work when we need a more powerfull power supply we usually just add another power supply of the same model and brand in parallel to double the output current.
    Thanx
    Guruj
  10. #30
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You probably read that in my power supply FAQ. You can run them in parallel. Of course, that means that you have to buy two of them.
    And I presume you're thinking you run the mobo on one PSU and the other stuff on the second PSU. That will work unless you can't split the power up between the two.
    Also, there are some new PSU's out there like the DSATX that help with those higher power boards.
    Want to:
  1. opus PSU too weak for me?
    By gummybear in forum Power Supplies
    Last Post: 03-04-2005, 01:46 PM
  2. Replies: 5
    Last Post: 02-28-2005, 03:42 PM
  3. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  4. FS: 90W Opus DC-DC PSU and extras
    By EBoundEE in forum Classified Archive
    Last Post: 06-28-2004, 01:54 PM
  5. Opus PSU for Casetronic C134
    By aethernaut in forum Power Supplies
    Last Post: 02-25-2004, 01:19 AM
