Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 78
Thread: FAQ: Hacking Your Steering Wheel Buttons to Control Your PC
  1. #11
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Another possibility:
    Some cars there is an option to buy one of the device sell at some audio places that convert those button to IR signal. The purpose of those device is when upgrading to after market HU, you are able to use those buttons to control the "new" HU like the factory one.
    Now, with the IR signal available, you can wire up a simple IR sensor with Girder and you are good to go. There is also a hack to use Lilliput IR sensor to control PC (you just have to search for this thread)
    What good about this compare to the one BugByte talking about? Well with this one, you can use other remote control you have laying around to control the PC at the same time as the sterring wheel buttons.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #12
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    link to one of these devices?
    PC Components:
    My work log
  3. #13
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Peoples
    Hit with "Steering Wheel Button IR" give this first link
    Pac Audio
    PIE is another one.
  4. #14
    Dec 2004
    Maryland
    so i guess this approach would be a little counter-intuitive, because you would need to find a device that IS NOT compatibile with your head unit. That way your headunit doesnt wig out when you are trying to control your PC. I guess if you dont have a head unit this is also a good solution. I notice the SWI-V has a list of headunits it is not compatible with, unfortunatly i think it is compatible with mine.
    PC Components:
    My work log
  5. #15
    Dec 2004
    Maryland
    i guess if you go with the SWI-X then its a learning IR so what i said above is not an issue. Good find matrix. .....no i have to many options on how to implement this....damn
    PC Components:
    My work log
  6. #16
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by MatrixPC
    I've looked into that, but as far as i'm concerned, it's a little to much, especially if you can take that 1 wire from the resistor network and figure out how to wire that into the game or serial port. Then there's no need for extra hardware...
  7. #17
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    See option 2 in the first post. There's a link to one at Crutchfield.
    Want to:
  8. #18
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Ipac and Mame are my friends..... the Ipac is ideal since it doesnt require drivers and software setup
  9. #19
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Can the IPAC be used to send three-key commands? I looked at the ultimarc website, but couldn't find an answer. I am wondering whether it could control volume, ff, rw, stop, mute, play, skip using Centrafuse which requires three-button presses (Ctrl+Alt+R, etc.)
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  10. #20
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Snootch cant u customize the sequences in Centrafuse????? I would think you could...
    Has anyone hacked a SWI-X or similar to convert the button presses into triggers for an ipac? I bought their minipac (works with spinners, trackballs and buttons) but I'm afraid I need a Swi-x for my car, and I dont want to add an IR if I can avoid it....one more point of falure, and I prefer things connected so I can see if they are "on"
    Roy
    2005 Range Rover 4.4
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  3. Steering wheel controls
    By Izik in forum Input Devices
    Last Post: 05-31-2004, 10:46 AM
  4. evaluate this in-dash tablet PC plan
    By dimas in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-15-2003, 07:50 PM
  5. pocket pc control?
    By meyer64 in forum Software & Software Development
    Last Post: 09-28-2002, 09:40 AM
