Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Laptop vs Desktop
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Laptop vs Desktop
    So you want a carputer, huh?
    Where do I start, oh where?
    How about the CPU? I've been seeing alot of postgs about using a laptop instead of a desktop, and vice versa. Well each system has it's pros and cons.
    Laptop Pros:
    Low-power
    Has a battery
    Let's system run for few minutes afer ACC went low
    Good durability (notebook hard drives)
    Small form factor
    Easily removed
    Laptop Cons:
    More Expensive
    Often require low-efficeny inverter is no DC-DC transformer available.
    Limited expandibility
    Hard to get "boot on power"
    Docking station may be needed
    Desktop Pros:
    Cheaper
    Usually a spare around
    Can build a Small form factor case
    GOBS AND GOBS of expandibility
    Some support "boot on power"
    No docking station required
    Desktop Cons:
    Larger size
    less power efficient
    If I forgot anything just shout and I'll throw it on.
    Jul 2005
    Lindenwold, NJ
    For laptop pros: often have exceptionally complete ACPI support allowing sleep, suspend, hibernate, battery/ac power monitoring, device activity, thermal monitoring, cpu throttling, device wake up, etc.
    For laptop cons: sometimes have exotic/proprietary devices/drivers.
    Also, I think docking stations help with the easily removed pro. I can take the laptop in, and leave everything hooked up and undisturbed in the vehicle with a port replicator/docking station.
    For desktop cons: often more heat (although my laptop get's plenty hot too)
    Actually, I think it's hard to make generalizations on many of these things. All can be overcome for either given time and money. I am assuming that more time/money equals con?
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    Desktop cons:
    Generally more expensive and more complicated powering solutions (Opus PSU, shut down regulators, etc.)
    Laptop pros:
    Most modern laptops come with built-in wireless cards
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Equipment prices favor desktops... Laptop parts are generally more expensive than the same spec desktop part.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I've been a long advocate for laptop systems. Let's see some easilly recognizable advantages:
    Laptop Pro's:
    - They come complete and ready out of the box
    - Low power consumption
    - Built-in screen (or video card that allows at least VGA out, sometimes S-video or composite too)
    - Small in size
    - Easilly powered and have internal battery for standby needs
    - Shock-resistand hard drives
    - Easy to add hardware
    - Easy to remove the whole system
    - Less worrying about overheating
    Laptop Cons
    - Hard to fix, rare spare parts (although not so with modern laptops)
    - Won't let you do major upgrades like CPU or video card (let's face it, is that even a factor when chosing your system?)
    - Easier to steal
    - Usually inferior sound/video cards (but personally I hardly feel any difference)
    Let's say you're on a budget. You need a simple system to play your music and do some GPS navigating. Do you chose to spend time and educate yourself on the ins and outs of building, powering and setting up a desktop (or those mini board things) or would you buy a cheap Pentium III laptop for $250? I'd chose the latter, so much easier.
    One more thing you're forgetting. Tablet PCs have even bigger advantage:
    - Small size
    - Built-in touchscreen
    - Same advantages as a laptop
    Tablets are so easy to install and use, they are small enough that you don't even have to remove the housing, just use the whole thing as your screen. Or if you want to fabricate it into your dash, nothing is easier! OK, higher end tablets are expensive. But if you're like me, and don't need to watch DVDs or play Half Life 2 in your car, then you can easilly afford $300 on a Pentium II tablet, it will do most things you need.
    My current setup cost me $90. Yes, you heard that right, includes shipping. It's a Pentium 166 with 32 mb of RAM and 7 GB hard drive. It runs Windows 98SE, has USB ports, Winamp is my front-end. I can listen to music and use GPS at the same time, I can use steering wheel controls with it. I can browse the web and wardrive with it. Wifi is there. I can put my main 2.8 GHz laptop on the back seat and remote control it from a touchscreen tablet in my dash via either LAN or WiFi. It's the ultimate budget pc, not to mention it sounds great and is incredibly stable and fast for what it is.
    Oh, and my LCD is 10 inches, not 7 Bigger is better, if you ask me
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Deleted some posts due to non-FAQ discussion.
    Want to:
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by TruckinMP3
    True but the large availability of USB2 & Firewire devices these days help offset that quite a bit. I'm assuming your referring to peripheral add-ons as opposed to replacement parts.
    Jun 2002
    Colorado
    Quote Originally Posted by shotgunefx
    Initial purchase and replacement/upgrade.
    TruckinMP3
    Read the FAQ!
    Oct 2004
    NY
    using a mobile designed computer in a mobile installation just makes sense...all of the things that make a laptop mobile are the things that make them benificial for in car use..... much lower power requirements& lower heat...two major hurdles in a carpc install..not to mention smaller....you can ALWAYS find a dc/dc solution.....of course there are unique problems that have to be overcome...but I think a laptop can make a better install than a desktop in most situations..
    better doesn't usually come cheaper though...unless you can use the screen in your install...then the bang for the buck definatly goes way up......alot of the times this isn't practical ...unless you want to do a lot more work or settle for a getto install in most cases...although there are exceptions....
    Constant Bitrate tdb30_'s Avatar
    Aug 2005
    Central MA
    Sometimes you can get deals on laptops with busted screens on ebay. This is a good deal for you if you are going to put your own screen in anyways.
  1. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  2. Need Desktop HD to laptop Mobo Connector
    By Joe_Collectible in forum General Hardware Discussion
    Last Post: 09-26-2004, 09:38 PM
  3. Laptop parts in a desktop
    By daguju1der in forum General Hardware Discussion
    Last Post: 07-25-2004, 03:36 PM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  5. laptop hdd in desktop
    By slackingoff in forum General Hardware Discussion
    Last Post: 08-11-2003, 10:22 AM
