FAQ: My Lilliput won't calibrate correctly.
If you're having a problem where your Lilliput (even if brand new) looks like this when you calibrate it:
http://i.mookie.org/lilli.jpg
Image stolen.. er borrowed.. from yamathegreat in this thread.
Then it looks like you need a new touchscreen overlay.
You may have some luck contacting whomever you bought the screen from and arranging a return, but if not the replacement panel can be found at DigitalWW... here.
They're a cinch to install. Carefully disassemble your Lilliput and remove the taped on touchscreen panel. Now remove the protective covering on the replacement panel and secure it on the screen with a little tape of your own. Hook its little connector up just like the old one was and reassemble your Lilli and you're good to go. Easy as that.
Edit: I'm sticking the word "calibration" in here so this thread will show up in searches :)
