Results 1 to 5 of 5
Thread: FAQ: My Lilliput won't calibrate correctly.
    Constant Bitrate mookie's Avatar
    Oklahoma
    If you're having a problem where your Lilliput (even if brand new) looks like this when you calibrate it:
    Image stolen.. er borrowed.. from yamathegreat in this thread.
    Then it looks like you need a new touchscreen overlay.
    You may have some luck contacting whomever you bought the screen from and arranging a return, but if not the replacement panel can be found at DigitalWW... here.
    They're a cinch to install. Carefully disassemble your Lilliput and remove the taped on touchscreen panel. Now remove the protective covering on the replacement panel and secure it on the screen with a little tape of your own. Hook its little connector up just like the old one was and reassemble your Lilli and you're good to go. Easy as that.
    Edit: I'm sticking the word "calibration" in here so this thread will show up in searches
    Progress: On hold while I pay off my new PowerBook :D
    Part List:
    VIA MII10000 - 512MB - 20Gig 2.5" - Rikaline 6010 - 7" Lilliput - CNX-P1260 - Alpine 4ch Amp - 4 Gauge wire and fused distrobution block.
    FLAC djmickyg's Avatar
    Feb 2004
    what lilliput has these issues?? the old or the new??
    Oklahoma
    For me it was the old one (619). The newer (629) may or may not have the issue also, I do not know for sure.
    Part List:
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    For the most part the new ones have been relativly trouble free compared the massive amounts complaints and threads about the old ones. They sourced a different touchscreen overlay that holds up better to heat and is less prone for failure.
    Disclaimer. This if not out of experience but from reading other peoples evaluations and posts
    Aug 1999
    Washington D.C.
    The Lilliput 619 has been through about 5 revisions in the past year and touchscreen are now more reliable then the Xenarc's. The 619 and the 629 Lilliputs both use the same internals they are not “older” or “newer” but rather different casings.
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Can't calibrate lilliput touch screen
    By _wd in forum LCD/Display
    Last Post: 02-14-2007, 11:10 PM
  3. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  4. Lilliput: Have to calibrate every 5 minute?
    By Burat in forum LCD/Display
    Last Post: 03-01-2005, 08:32 PM
  5. Can´t calibrate lilliput 100%
    By yokeren in forum LCD/Display
    Last Post: 01-18-2005, 07:36 PM
